June 03, 2026, 07:22:56 PM *
Pages: 1 ... 42 43 [44] 45 46 ... 48
Author Topic: Rennies Trike  (Read 349416 times)
« Reply #645 on: July 21, 2014, 07:03:37 AM »
i think i know where you found the choke idea  Wink Wink
was it yours Mike?
« Reply #646 on: July 21, 2014, 10:44:00 AM »
Used on this one
« Reply #647 on: July 21, 2014, 10:44:37 AM »
...& this one
« Reply #648 on: July 21, 2014, 10:45:19 AM »
...& this one
« Reply #649 on: July 21, 2014, 10:46:24 AM »
...& this one
« Reply #650 on: July 21, 2014, 10:47:09 AM »
...& this one
« Reply #651 on: July 21, 2014, 10:48:12 AM »
...& this one
« Reply #652 on: July 21, 2014, 10:48:42 AM »
etc, etc, etc.
« Reply #653 on: July 21, 2014, 10:52:54 AM »
has ha ha. Knew i'd seen it somewhere Smiley
« Reply #654 on: July 21, 2014, 11:02:41 AM »
But not this one  Cheesy
Here you can see the insulation. Do you think microbore copper tube will wrap around that tight without crushing. If it does soldering in place would help heat transfer.
« Reply #655 on: July 21, 2014, 01:39:35 PM »
Would look great if it works.
Mendalot
« Reply #656 on: July 21, 2014, 02:17:50 PM »
I managed to coil 8mm copper pipe around a 2.5 inch induction pipe for a turbo engine to help cool the charge before it went into the inlet manifold. After several attempts with the pipe flattening out, I filled the tube with brake fluid and crimped both ends tight, then it wrapped around easily with out any distortion.
« Reply #657 on: July 21, 2014, 03:09:49 PM »
Good idea i was going to try sand!
« Reply #658 on: July 22, 2014, 07:49:41 PM »
etc, etc, etc.
and this one  Smiley
« Reply #659 on: July 22, 2014, 08:27:28 PM »
OHHH! I like that one Grin and I dont get trikes!
