June 03, 2026, 09:07:04 PM *
Pages: 1 ... 41 42 [43] 44 45 ... 48
Author Topic: Rennies Trike  (Read 349458 times)
« Reply #630 on: June 08, 2014, 08:54:51 PM »
Relaxed Position
« Reply #631 on: June 08, 2014, 08:55:20 PM »
Go Faster Position
« Reply #632 on: June 08, 2014, 08:56:08 PM »
The bits you show are looking good ,when can we see the whole trike
Ok Merv. Will pus her out in the next few days and take some pics. Nothing much to see yet though.
« Reply #633 on: July 13, 2014, 11:16:10 PM »
I am fitting an electrical oil pressure guage as well as an oil warning light. The sender is huge!. After a lot of thinking and googling i came to realise that the spare facit petrol pump i have has 1/8th NSF threaded connectors. One of these fits perfectly into the oil pressure switch hole. So I ended up making a new aluminium "mainfold" to carry the sender and switch, which can be fed from the existing outlet. looks different! The nice thing about this is that i will be able to pick up the wires from the temp sender and these 2 senders into a single loom.
« Reply #634 on: July 13, 2014, 11:22:24 PM »
I wanted to try to make the HT leads look neat. My original thought was to take them up and back down in a bunch onto the dizzy top. The plugs for cyl 1 and 2 foulded the dizzy so that wouldnt work Sad so plan 2 is now in force. I have made a silicon rubber ht lead spacer so the leads come out of the dizzy neatly. more to do yet
« Reply #635 on: July 13, 2014, 11:25:07 PM »
And finally got around to fitting the axle breather after seeing Pete's post!
twisted
« Reply #636 on: July 14, 2014, 09:04:12 AM »
nice work there sir well done  Wink
« Reply #637 on: July 14, 2014, 06:09:24 PM »
looks good Andy
« Reply #638 on: July 17, 2014, 09:46:12 PM »
Glad it was of use to you  Smiley
« Reply #639 on: July 20, 2014, 08:14:32 PM »
Today I made a new bend to go between the carb and the manifold. I had altered the original reliant one, but wasn't happy with it and the dashpot plunger was a little close to the tank and hard to get out, much happier with this now. Its steel, but i think if i paint it aluminium coloured or the colour of the frame it will look ok
« Reply #640 on: July 20, 2014, 08:28:40 PM »
looks good,i'de go body colour. i like your choke lever very stright foward and effective
« Reply #641 on: July 20, 2014, 08:46:17 PM »
Neatly done sir. Found that I had to wrap mine in insulation, to help retain the heat transferred from the manifold. Think the fuel was condensing on the back wall of the bend.
« Reply #642 on: July 20, 2014, 09:45:42 PM »
Cheers. I saw that somewhere else and swiped the idea. Will need some bracket ray i think
« Reply #643 on: July 20, 2014, 09:49:09 PM »
Thanks Olds. I did wonder about that as the original reliant had a water jacket. I am toying with the idea of a spiral wrap of copper microbore central heating pipe and running the water through as the original reliant did.
« Reply #644 on: July 20, 2014, 11:37:00 PM »
i think i know where you found the choke idea  Wink Wink
