June 03, 2026, 08:19:18 PM *
Pages: 1 ... 40 41 [42] 43 44 ... 48
Author Topic: Rennies Trike  (Read 349438 times)
« Reply #615 on: April 28, 2014, 03:00:57 PM »
close up of the rubber. has small ridges in it
« Reply #616 on: April 28, 2014, 07:28:39 PM »
I have used a rubber with small ridges on it  Wink
« Reply #617 on: April 28, 2014, 08:10:37 PM »
 Grin Grin Grin Grin Grin Grin Grin
« Reply #618 on: April 28, 2014, 08:12:16 PM »
That's a bit sensitive. Grin
« Reply #619 on: May 03, 2014, 08:20:46 PM »
Spent a bit of time on one the rear muddguards today. Made the box to receive the front position light and plumbed in the wires round to the back. After working on the inner arch for some time moved to the outer arch and sculpted it up a bit. Not happy with it yet, as it needs a little more material adding to make it more rounded but its getting there. I am going to polish the stainless up  and run the colour of the frame up from the frame round to the back on the outside as a small band of colour, that will cover up the filler and a little of the stainless. I hope that comes out ok.
Wont be able to do any more on her for a week now as im going doing a bit of "international monkey of mystery" travelling again, fly out tomorrow am at 8:30 Sad
« Reply #620 on: May 03, 2014, 08:57:47 PM »
Are you being parachuted into a trouble spot somewhere?
« Reply #621 on: May 03, 2014, 08:58:56 PM »
Cause trouble everywhere i go Smiley
« Reply #622 on: May 03, 2014, 09:04:08 PM »
Remember to send back pics. We like pics  Smiley
Hope the trip goes well mate.
« Reply #623 on: May 26, 2014, 09:57:06 PM »
Spent a bit of time on the build today. Cut the oil filler of the rocker cover and welded it up. Also made the bracket on the rocker cover for the coil. Fitted the brake m/c yesterday. A little further forward.
« Reply #624 on: June 08, 2014, 08:28:20 PM »
Working my way around the rear when the mood takes me. Some progress.
« Reply #625 on: June 08, 2014, 08:33:05 PM »
Fitted the remote master cylinder. It is at the highest point in the system.
« Reply #626 on: June 08, 2014, 08:38:39 PM »
Probably going to fit the coil here. Looks balanced against the dizzy. The HT leads can all run vertically, and drop down is some form of nice harness onto the dizzy cap.
« Reply #627 on: June 08, 2014, 08:46:56 PM »
The bits you show are looking good ,when can we see the whole trike
« Reply #628 on: June 08, 2014, 08:48:12 PM »
Watching ON change deliverance gave me an idea. The Trike has 2 uses, tootling about with Cath and Will and touring abouit the UK with Cath. So Deciced to make it convertable from 3 seats to two seats. Also the single seat setup will have a higher rear seat so Cath can see over me head.Did a bit of adjustment to the third galaxy seat I kept back, here it is fitted centrally.
« Reply #629 on: June 08, 2014, 08:51:54 PM »
Rear seat mounted up with suspension Smiley
