June 03, 2026, 09:06:49 PM *
Pages: 1 ... 39 40 [41] 42 43 ... 48
Author Topic: Rennies Trike  (Read 349457 times)
« Reply #600 on: April 16, 2014, 05:59:46 PM »
Unless your nuts are wobbly  Wink
« Reply #601 on: April 16, 2014, 07:33:33 PM »
My nuts are wobbly but only when I run . Shocked
« Reply #602 on: April 16, 2014, 07:52:17 PM »
 Cheesy Cheesy Cheesy Cheesy
« Reply #603 on: April 24, 2014, 10:26:24 PM »
Just done a little past few days. Finished the rear brake mechanism, and fitted the horn. Got a hazard switch and fitted it into the instrument pod.
« Reply #604 on: April 26, 2014, 09:24:07 PM »
So here is the populated instrument pod.
« Reply #605 on: April 26, 2014, 09:26:33 PM »
Here is the rear brake lever/pedal
« Reply #606 on: April 26, 2014, 09:26:55 PM »
And the horn Smiley
« Reply #607 on: April 26, 2014, 09:31:07 PM »
So today i started on the rear light pods. I wanted to use some lovely old glass lenses i got some time ago in individual tubes. But then I realised I was taking a big risk with the MSVA. so to be  honest
I bottled it!
Plan B - fit E marked LED lights. I considered hamburgers, as the trike is curvy, but decided against tht as they would be too round! So slightly curved ractangular on in hand, i destroyed it a little by cutting the box off the back!
« Reply #608 on: April 26, 2014, 09:37:15 PM »
Doesnt look much at the moment, but i made up steel pods to take the cut down lights. These have plenty of gentle curves and follow the frame (sort of!)
Once i apply a bit of filler and a lot of elbow grease I hope to nake them look natural and flowing.
twisted
« Reply #609 on: April 26, 2014, 11:01:02 PM »
loving the instrument cluster very smart and the horn  Wink. keep it up mate
« Reply #610 on: April 27, 2014, 08:39:26 AM »
those taillamps look the job Andy
« Reply #611 on: April 27, 2014, 09:55:07 PM »
Thanks guys! Finished the tail light fixings off today. Cut slots in the top and tacked a couple of lugs to the cowls that will engage.
And araldited a plate with a with a nut welded to it onto the bottom of the lights
So to fit the lights  i offer them up from below, then push the base in and insert a small bolt from below.
« Last Edit: April 27, 2014, 09:57:08 PM by andyrennison » Logged
« Reply #612 on: April 27, 2014, 10:01:27 PM »
Then I started on the rear mudguards. Cut a hole for the front marker light and mocked up the look i want on the arch with sticky paper and card!
« Reply #613 on: April 27, 2014, 10:10:47 PM »
Bent up some 10mm cooper pipe  to form the lip of the arch and fixed it into place with glassfibre and expoxy.
The wire for the front marker light will run through the copper.
The tools various are to keep the pipe flat and in place
« Reply #614 on: April 28, 2014, 03:00:11 PM »
Rubber came today for the footrests and sundy other uses maybe?  Very pleased with this 1 meter by 2.5 meters for less than £20 off e-bay
