June 03, 2026, 11:10:22 PM *
Pages: 1 ... 37 38 [39] 40 41 ... 48
Author Topic: Rennies Trike  (Read 349516 times)
goose
« Reply #570 on: October 29, 2013, 11:39:09 AM »
looking good mate
« Reply #571 on: January 12, 2014, 07:43:11 PM »
Been doing a lot the past few weeks. I have finished making the bars, which include a plate that bolts to the existing headstock. All wires and cable run in the inside. Quite pleased with them, will put a pic up soon. Also made a little glass fibre pod for the volt meter, temp and oil pressure gauges.
steven brock
« Reply #572 on: January 12, 2014, 10:31:30 PM »
Keep it up fella Smiley
« Reply #573 on: January 13, 2014, 09:08:49 AM »
Handlebars, glass fibre, sounds like you have been busy  Smiley
Where's the pics  Wink  Cheesy Cheesy Cheesy
dobber
« Reply #574 on: January 13, 2014, 08:42:54 PM »
Andy, did we get sorted on the receipt you needed for the engine for the registration. dint recall if i sent it or not.... how did you get on with it?
        can i have it in 20 Min's?
« Reply #575 on: April 09, 2014, 08:05:23 PM »
Hi  Dobber. Dont think I got it. Some sort of receipt would be good just so I can prove its a legit engine. Cheers Smiley
« Reply #576 on: April 09, 2014, 08:12:52 PM »
OK, here are the pics. Im getting back on the horse now Smiley
Firstly, the bars. The grips will be heated and has a little control box. So i made a small container for it at one bar end
« Reply #577 on: April 09, 2014, 08:14:14 PM »
And brought the brake line and accelerator cable out through little angled tubes
« Reply #578 on: April 09, 2014, 08:16:55 PM »
the brake line passes down an upright and onwards through to and past the lower yolke and out, ready to  connect to the flexies to the calipers
« Reply #579 on: April 09, 2014, 08:18:13 PM »
the overall look will be quite clean I think
« Reply #580 on: April 09, 2014, 08:19:53 PM »
here is the glassfibre pod mounted with the other clocks. May be a bit top heavy, will reconsider this once ive got the SVA!
« Reply #581 on: April 09, 2014, 08:22:32 PM »
Clocks and pod mounted
« Reply #582 on: April 09, 2014, 08:26:43 PM »
Then turned my attention to the rear brakes. Finally fabricated this lot. The outer tube has to be welded to the footboard like the clutch side is, and the end will be radiused to match the pedal.
I will insert silicon rubber discs into the slots to end up with slightly raised rubber ridges. The pedal itself will be nickelplated.
Missing is the return spring, which wraps around the shaft, recovered from the old reliant brake pedal.
« Reply #583 on: April 09, 2014, 08:37:18 PM »
I was unhappy with the wheel spacer / stud extender system i got off ebay. Also the wheels are 100 pcd so didnt really work on the 4" pcd studs.  I dont have a lathe, but managed to make this adapter.
Marked it out and then using a hacksaw took off as much material to get it round as i could, then got it a little more round with a 40 grit flap disk in the angle grinder.
I drilled a small hole in the centre and put through a long bolt, which also went through a bearing. plates and nuts were used to clamp the rough ally disk tightly onto the bolt.
Put the free end of the bolt into my bench drill, and clamped the bearing at the bottom.
With the drill running on low speed the whole thing spun securely.
Then brought up the angle grinder very gently and slowly slowly allowed it to becone round.
once i had a nice round thing swapped to a 120 grit flap dick and polished it up a little. Then finally used emery cloth.
To get the centre hole I used a bimetal hole saw, and again took it easy and used plenty of cutting grease.
next job is to fit the new studs to the hubs, and the 12mm studs into the adapter.
« Reply #584 on: April 09, 2014, 08:41:46 PM »
Last pics for tonight. I have just got these little parts. The circuit board and wire are a 12 volt temperature sensor. I intend to fit the pressure gland to the bottom of the rad, and somehow put the sensor through it into the water at the bottom of the rad. The relay will turn the fan on and off. The on / off temp is set with the little switches. Hope this will be a neat and flexible way of managing the electric rad fan.
