June 04, 2026, 12:56:30 AM *
Pages: 1 ... 33 34 [35] 36 37 ... 48
Author Topic: Rennies Trike  (Read 349587 times)
« Reply #510 on: July 24, 2013, 09:14:35 PM »
You used to be able to buy custom footpegs called "Sundance" pegs. They were chromed with grooves machined around them & rubber O rings fitted. Unfortunately the O rings used to break & fall off as your feet rubbed them. So you either had to put in a regular order for new O rings from your local bolt shop or hydraulics supplier, or run the pegs without rubbers.
I assume the pedal sections are welded to the arms now so can't be put in a lathe & knurled?
« Reply #511 on: July 24, 2013, 10:15:59 PM »
They are welded (well, it is, not done the brake yet) Could soon cut it off, but not got any knurling facilities.
I did wonder about knurning, will mull that over .......
« Reply #512 on: July 25, 2013, 09:19:11 AM »
Hmmmm
I wonder if this idea could be adapted ....
http://www.ebay.co.uk/itm/SILVER-RUBBER-GRIP-ALLOY-PEDAL-SET-ALUMINIUM-SPORTS-CAR-FOOT-PEDALS-3-PCE-KIT-/300717793665?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item46042d6181
« Reply #513 on: July 25, 2013, 06:37:17 PM »
what about the grippy paint used on step edges etc,mask of an area paint it and leave the rest as is ,seems a shame to cover those nice pedals
like this
http://www.ebay.co.uk/itm/NON-SLIP-CLEAR-MATT-PAINT-ANTI-SLIP-TEXTURED-GRIP-STAIRS-/190844743798?pt=UK_DIY_Material_Paint_Varnish_MJ&hash=item2c6f3bb076
« Reply #514 on: July 25, 2013, 08:04:59 PM »
dont forget to check if your trike is in the "compatible vehicles list" Smiley Roll Eyes
« Reply #515 on: July 25, 2013, 09:03:11 PM »
like this
That looks like interesting stuff, I've send for a tin to see how good it is.
« Reply #516 on: July 25, 2013, 09:03:45 PM »
Ha ha, see the following posts, i've been playing
« Reply #517 on: July 25, 2013, 09:04:33 PM »
So I started with a sheet of 10mm thick silicon rubber and chopped a bit off the corner
« Reply #518 on: July 25, 2013, 09:06:27 PM »
Then I cut an 8mm slot in a piece of scrap, and poked the silicon into it. If I go for this idea I will add a big blob of silicon rubber to the bottom to glue it in
« Reply #519 on: July 25, 2013, 09:07:44 PM »
finally a bit of shaping with the angle grinder and a sanding disk on the silicon rubber produced this
stumpy
« Reply #520 on: July 25, 2013, 09:09:36 PM »
send them to me i will knurl them for you just cover the postage
« Reply #521 on: July 25, 2013, 09:09:50 PM »
With a bit of care a few of these may also look nice. Will try the anti slip paint that scannerzer came up with as well first before I decide. This way adds a little texture, could be good, could be bad.
« Reply #522 on: July 25, 2013, 09:11:26 PM »
Cheers Stumpy. So now I have 3 options, none slip paint, silicon rubber inserts and knurling. Decisions decisions. Must admit I like the idea of knurling.
« Reply #523 on: July 27, 2013, 12:00:31 PM »
did a little today. Tacked in the fuel pump bracket. Checked the tank for water tightness and made good a little weep at a weld with some new weld Smiley
The inline filter will be positioned between with stainless braided connecting the lot. Might spay the pump "chrome" to bling it up.
stumpy
« Reply #524 on: July 27, 2013, 03:57:17 PM »
looks good bud i hope for your sake the fuel pump never leaks above all that voltage of the ht leads !!! apart from that sound job
