June 04, 2026, 01:02:23 AM *
Pages: 1 ... 32 33 [34] 35 36 ... 48
Author Topic: Rennies Trike  (Read 349600 times)
« Reply #495 on: July 13, 2013, 08:24:13 PM »
nice work with the exhaust and the jack ,looks good on both counts.
« Reply #496 on: July 16, 2013, 01:05:52 PM »
Thank you
« Reply #497 on: July 20, 2013, 10:52:19 PM »
Spent a day adding oilite bushes to the clutch assembly - pics to follow. Looks good to my eye Smiley
So, been planning the new forks and rocker for the leading links. Forks will be 44.45 mm CDs, 4.44mm wall. Rocker and bale will be rectangular section 60x40 mm 3mm wall. Rocker will articulate onto the forks using 25mm id brass bushes inside a crush tube in the rocker. Wheel bolt will pass through the centre of the rocker inside a crush tube. Callipers will be free floating and tied back to the forks. Does anyone have good or bad things to help me with that idea before I go ahead and spend me dosh ?
« Reply #498 on: July 21, 2013, 05:54:13 PM »
Here is a pic I hope of the updated clutch pedal. Tried to electroplated the lever and trollied it, not enough current I think, will try again on Tuesday. Pleased with the oilite bushed and mild steel rod.
« Last Edit: July 21, 2013, 06:24:59 PM by andyrennison » Logged
« Reply #499 on: July 21, 2013, 08:22:32 PM »
ehhhh nope  Shocked
« Reply #500 on: July 21, 2013, 08:43:01 PM »
Cant get it to upload off my phone. Will do it when i get to my hotel Smiley
« Reply #501 on: July 21, 2013, 11:07:19 PM »
Here it is. If I can sort out the electroplating it should look ok.
« Reply #502 on: July 22, 2013, 07:28:16 AM »
Can you show us the process Andy ,it sounds interesting .pedals look nice by the way
« Reply #503 on: July 22, 2013, 07:54:58 AM »
Will do. Once i have got it sorted out and know what i am doing i will start a thread on it. Not really in a position to show and tell yet as its still hit and miss!
« Reply #504 on: July 22, 2013, 07:56:54 AM »
Looking forward to the coming thread
« Reply #505 on: July 22, 2013, 01:13:24 PM »
Yeh me too
« Reply #506 on: July 23, 2013, 09:12:48 PM »
My needle is waiting to be electroplated ready for the thread as well .  Grin
« Reply #507 on: July 24, 2013, 10:08:27 AM »
looking good, what you using for non-slip on pedals?
« Reply #508 on: July 24, 2013, 06:26:19 PM »
Not sure yet. Either:
Weld on some part arcs to follow the curve, that can then be plated in with the rest
Put on cylindrical rubber bands, old pushbike bike inner tube stretched over in rings was a thought
Try to make some rings out of silicon rubber plate.
All ideas welcomed!
stumpy
« Reply #509 on: July 24, 2013, 07:08:09 PM »
KNURL IT
