June 04, 2026, 02:18:58 AM *
Pages: 1 ... 29 30 [31] 32 33 ... 48
Author Topic: Rennies Trike  (Read 349741 times)
« Reply #450 on: June 08, 2013, 08:38:51 PM »
Nice soft seat you have there, I guess this idea looks cool but may rupture a disc or summat Smiley
http://i1061.photobucket.com/albums/t466/steveatthemorgue/cool%20bike%20pics/null_zpse21cff77.jpg
Rennies Trike
looks like something you would find in an S&M dungeon, not that i would know  Huh
« Reply #451 on: June 08, 2013, 08:43:47 PM »
Andy
   Had you thought of mounting it closer to master cylinder?
 Cool
Do you mean put the res on th mc bracket?
Yes, make bracket to fit the upper bolt that holds mc to chassis, with shorter connecting hose Smiley
that's a thought! I was originally going to mount it above the rear caliper height. Maybe with the residual pressure valve i don't need to.
« Reply #452 on: June 10, 2013, 09:53:02 PM »
Started on the handbrake while I ponder the remote reservoir position. Made a plate to bolt it to and welded it in. the lever has a rod coming out at right angles which goes through 2 rubber bushes on the frame. I will run the cables along the centre of the frame to the compensator thingy and then on to a tang on the rotating cross rod.
« Reply #453 on: June 10, 2013, 09:54:31 PM »
side view
dobber
« Reply #454 on: June 14, 2013, 09:25:54 AM »
this has really moved on since i last visited the site to have a good look round. you on it regular Andy
        can i have it in 20 Min's?
« Reply #455 on: June 14, 2013, 04:14:02 PM »
Do what I can, usually some every week. I travel for work some weeks which takes my time away. Want to get is MSVA'd before the end of the year Smiley
steven brock
« Reply #456 on: June 14, 2013, 05:32:33 PM »
Awesome work
Mr_G
« Reply #457 on: June 14, 2013, 08:31:28 PM »
Nice work!
Can't imagine that bending a brake disc would be very easy to achieve! Or is it just serverly warped?
« Reply #458 on: June 14, 2013, 08:43:11 PM »
Nice work!
oxy,,accetelyne,,, oil .helps bending things Wink Wink
« Reply #459 on: June 14, 2013, 08:55:17 PM »
Brake disk not on my trike, I guess a lot of heat was involved though
« Reply #460 on: June 30, 2013, 06:35:56 PM »
Made a handbrake adjuster / compensator this weekend
« Reply #461 on: June 30, 2013, 06:39:22 PM »
And a clamp for the handbrake cables. I can cut the sheath of the outside now and run the inners under the three screws on each arm. The idea is that the scews will hold the cable, and the lock nuts will keep the screws from rattling out.
« Reply #462 on: June 30, 2013, 06:42:03 PM »
Drilling out the centre hole for the handbrake cables, had to go slow on this.
« Reply #463 on: June 30, 2013, 06:43:48 PM »
One leg drilled and tapped
« Reply #464 on: June 30, 2013, 06:46:07 PM »
Scalloped the tube for the adjuster to help hold the nut at each end while it was welded in.
