June 04, 2026, 04:27:42 AM *
Pages: 1 ... 25 26 [27] 28 29 ... 48
Author Topic: Rennies Trike  (Read 349850 times)
« Reply #390 on: April 17, 2013, 08:02:16 PM »
Still investigating my leading link front end. Anyone got an opinion on these?
http://www.ebay.co.uk/itm/45mm-Billet-Aluminium-Yokes-suitable-for-use-with-Monkey-Bike-Motorcycles-/200903559572?pt=UK_Motorcycle_Parts&hash=item2ec6c90994
« Reply #391 on: April 17, 2013, 08:14:02 PM »
NO. Please do not contemplate this.
Designed for a very small light bike. Look strong but will be very light as most of the material has been machined away underneath.
Looks like even the stem is alloy.
« Last Edit: April 17, 2013, 08:17:04 PM by Old Newbie » Logged
« Reply #392 on: April 17, 2013, 08:15:00 PM »
Cheers. Seemed to good to be true Smiley
« Reply #393 on: April 17, 2013, 08:43:17 PM »
They are for a Monkey Bike not Monkey Trike. Cheesy Grin
« Reply #394 on: April 17, 2013, 08:56:11 PM »
ha ha. are these more like it - still 45mm Smiley
http://www.ebay.co.uk/itm/Honda-CBR900-RR-CBR-900-CBR900RR-yoke-yokes-triple-steering-stem-/121086996742?pt=UK_Motorcycle_Parts&hash=item1c3158f106
« Reply #395 on: April 17, 2013, 09:31:09 PM »
I you want to use yokes off anything why not use some from upside down forks Bigger diameter.
« Reply #396 on: April 17, 2013, 09:44:10 PM »
i saw a few at 48 mm but hellish expensive. I could go to custom made yokes, but that will be a lot of £££ I think  Sad
« Reply #397 on: April 17, 2013, 09:49:41 PM »
If you know someone that could bore the holes for you ,
You could do the rest yourself.
« Reply #398 on: April 17, 2013, 09:53:31 PM »
I suppose so, its the hole accuracy that makes or breaks em i suppose. Maybe I can find a local engineering firm tha cam do that for me. Just no Idea of what im doing with this - eeeek
« Reply #399 on: April 17, 2013, 10:01:03 PM »
I suppose a good staring point would be wheel width.
That will give you an idea on the hole spacing.
« Reply #400 on: April 17, 2013, 10:10:43 PM »
Thats the trigger i needed Hunter:)
If I start there I can get the caliper carriers in , speedo drive etc and that will then set me a width between the rockerss. I could rough all that out to prove how I was going to do it. once I knw that I can work uphill on my dimensions Smiley
I have a fat bob style tank on, so wider stachions (and fatter ones) will give it a more balanced look I suppose
« Reply #401 on: April 18, 2013, 02:17:30 PM »
Just curious..What do you reckon the weight will be when finished then Andy? Mines 300kg unladen ,but seems to have a lot less stuff on it that yours? (and I was put off pulling a small trailer,cos I dont want to strain the clutch!lol)
« Last Edit: April 18, 2013, 02:19:51 PM by ROD » Logged
« Reply #402 on: April 18, 2013, 03:15:59 PM »
i wouldn't worry about the clutch Rod. i standard reliant weighs just over 400kg and it can carry 4 adults  Shocked. so yours at 300kgs plus 2 adults. that leaves 100kg plus 2 adults and a bit to play with Wink
« Reply #403 on: April 18, 2013, 03:35:11 PM »
i used to tow break downs in with a robin van when i was a teenager , i used and abused it as much as possible never ,killed, a clutch wore a couple out through general wear and tear , and even snapped a crank off behind the flwheel,, but as i say clutch,s stood up to it very well.
« Reply #404 on: April 18, 2013, 10:14:46 PM »
Maybe its deceptive Rod. True there are 2 chairs to the rear and a little steel behind them, other than that its about the same I think. Currently weighs about 250 kg with all the stuff on, I am expecting 300 - 350 when its finished.
