June 04, 2026, 07:36:39 AM *
Pages: 1 ... 16 17 [18] 19 20 ... 48
Author Topic: Rennies Trike  (Read 350015 times)
« Reply #255 on: January 03, 2013, 10:31:25 AM »
I was just going to electroplate the tube with replica chrome - not sure about the plastic handle yet - maybe an anodised aluminium knurled knob.
Mendalot
« Reply #256 on: January 03, 2013, 11:15:51 AM »
Its great to see an idea take shape ..... good stuff Andy Cheesy
steven brock
« Reply #257 on: January 03, 2013, 01:00:02 PM »
I couldn't figure out how the dipstick tube came out
« Reply #258 on: January 03, 2013, 01:17:36 PM »
This is nothing to do with the dipstick Steve. It is purely a mod to the fuel pump casing to allow it to be an oil filler, fitted where the fuel pump used to be. Dipstick is untouched.
« Reply #259 on: January 03, 2013, 02:26:26 PM »
Thats a bloody good idea Andy, will you be cutting off the filler kneck from the rocker cover and filling up the hole?
« Reply #260 on: January 03, 2013, 02:34:17 PM »
Hi tbone. I wasnt going to, as that also has the crankcase breather in it back to the carb. I am thinking that needs leaving in place otherwise the crankcase pressure will rise and maybe end up pi***ng leaking oil everywhere? For the record Steven Brock mooted the idea Smiley
« Reply #261 on: January 03, 2013, 05:07:28 PM »
Im running my breather pipe from the cap to open air,had no probs. You could cut the rocker cover filler neck off and just weld in a stub for the breather?
« Reply #262 on: January 03, 2013, 06:10:54 PM »
Hi Rod. Thats a thought as well, would make the top look more streamlined for sure. If the breather is going to vent to atmosphere it can be anywhere i guess, so maybe I can incorporate it into the dip stick knob. Is this venting to atmosphere ok for thr MOT?Huh
« Reply #263 on: January 03, 2013, 06:44:40 PM »
Ah that Rod beat me to it!  Grin
Yes it`ll be fine, the MOT man wont be worried  Wink
« Reply #264 on: January 03, 2013, 07:13:53 PM »
Thats that sorted then Smiley - off out tome make a bit more now.
« Reply #265 on: January 03, 2013, 09:16:02 PM »
Your MOT man might want you to clip the vent pipe so it doesn't flap about, probably point it down to the road under the trike & possibly away from heat sources like the hot exhaust, (explosive vapours). Removing the rocker cover filler neck & replacing it with just a pipe would look tidy though.
Re-using the fuel pump housing's very clever, though I think Id've gone with a short filler tube welded to a flat plate, bolted to the pump mounting holes, with a knurled, push in or screw in filler cap.
Clever, lateral thinking.
bitzman5
« Reply #266 on: January 03, 2013, 10:26:48 PM »
you could also put a tiny K/N filter at the end of the breather pipe
« Reply #267 on: January 03, 2013, 10:43:44 PM »
I wonder if I couild put thje filter onto the end of the dipstick as its "knob" are the little ones strong enough?
More pics in 15 mins - Andy will like what he sees I think Smiley
« Reply #268 on: January 03, 2013, 11:04:05 PM »
Here we go, a short tube attached to a bolt on flange. Is that wht you had in mind Andy? - Edit - Just reread Andys post, not its not. Ha ha ha Smiley - Edit -
Need to add the "sloping" metal on the filler end of the tube to lock the filler cap down when twisted, then its a file, polish and plate job Smiley
« Last Edit: January 03, 2013, 11:06:57 PM by andyrennison » Logged
steven brock
« Reply #269 on: January 03, 2013, 11:42:08 PM »
Post it over ill powder coat it for ya Smiley i like it
