June 04, 2026, 07:36:59 AM *
Pages: 1 ... 15 16 [17] 18 19 ... 48
Author Topic: Rennies Trike  (Read 350017 times)
« Reply #240 on: December 31, 2012, 10:06:17 PM »
Normally a dry fit, but Reliant engineering's pretty basic. I'm sure a suitable sealant wouldn't do any harm.
« Reply #241 on: January 01, 2013, 07:37:01 PM »
Thanks Steve and Andy. Ok, I'm going to run a fingerfull of sealant around the rim when I reassemble it. So here are a few pics of
a) the diff after degreasing ready for inspection
b) same diff in freezer bags to keep it clean from contaminents now it sparkly clean there it will now stay until I reassemble
c) diff housing cleaned, sanded and primed Smiley
« Reply #242 on: January 01, 2013, 07:39:24 PM »
Diff
« Reply #243 on: January 01, 2013, 07:40:09 PM »
2
« Reply #244 on: January 01, 2013, 07:40:48 PM »
3
« Reply #245 on: January 01, 2013, 10:08:19 PM »
Oooh, get you -all organised n stuff!
Very nice mate.
steven brock
« Reply #246 on: January 01, 2013, 11:12:46 PM »
Great keep pics coming Smiley
« Reply #247 on: January 02, 2013, 10:33:35 PM »
Cheers guys. Did a little more this evening, proper paint on the dif cases nowand painted up a hub and disk.Also started on the conversion of my bust fuel pump to an oil filler. This pic shows the type of fuel pump fitted to my lump
« Reply #248 on: January 02, 2013, 10:39:01 PM »
Removed the top and the pin that holds the cam follower, then took out the gubbins. The diaphragm is removed by rotationg it by 90 degrees. To my suprise I found a lovely steel wowl below the diaphragm. The bottom of the bowl had a ring of aluminium coming back up. The ally ring was milled away using the dremmel and the hole which the diphragm shaft goes through was made bigger so the oil will be able to flow more easily.
« Reply #249 on: January 02, 2013, 10:41:21 PM »
I had hoped to use a Radiator cap as the oil filler cap, and found that the rubber ring of the cap fits snugly part way down the steel bowl. Perfik!
« Reply #250 on: January 02, 2013, 10:43:13 PM »
So I made a ring for the upper seal of the cap to fit down onto. Th eplan is to make a lower ring that will bolt onto the pump body, and connect the 2 with a short piece of pipe.
« Reply #251 on: January 02, 2013, 10:45:13 PM »
The gasket to fit the new assembly will be cut out of the old diaphragm, as it is already the right fit Wink
steven brock
« Reply #252 on: January 03, 2013, 12:37:34 AM »
Couldn't you just have a flange plate and tube with a bung out at 45 degrees?
Or iz this a feature to resemble the original ?
« Last Edit: January 03, 2013, 07:57:14 AM by steven brock » Logged
« Reply #253 on: January 03, 2013, 09:15:40 AM »
I am hoping to get a small squat result. I really didnt want a structure running at an angle so I thought i'd have a go this way Smiley
steven brock
« Reply #254 on: January 03, 2013, 10:00:33 AM »
Fair enough any idea of dipstip or use original?
