June 04, 2026, 05:08:18 AM *
Pages: 1 ... 10 11 [12] 13 14 ... 48
Author Topic: Rennies Trike  (Read 349876 times)
« Reply #165 on: July 20, 2012, 05:48:44 PM »
Apparently it rotates ok, he seems to be a guy who knows what he is doing so I took a chance. I have a rebuilt engine, but I do like the look of steves little reliant trike, so I collecting parts for a low cost second build /spares. Andy, up here we need more than kags this past few months, its been terrible - I suppose it could also have been one of those 'orrible safety jackets Smiley
steven brock
« Reply #166 on: July 20, 2012, 08:22:06 PM »
Low cost! Rotflmao  Cheesy
« Reply #167 on: July 20, 2012, 08:32:35 PM »
Some reckon it can be done..........
« Reply #168 on: July 23, 2012, 07:54:17 AM »
A good weekend. Worked out how to drive the petrol guage in the GS tacho clock from a reliant sender. So have turned the sender upside down on the feed pipe and blacnked off the pipe. Ground off the old petchck fitting on the tank ans made fitted a new one. Rest of the week will be fitting the new sender to the underside of the tank.
The GS tach is being removed and the various warning lights fitted to the face, just ordered those.
Had the engine running again the newly run exhaust seems to work ok ( a little loud? ) so that has worked out ok.
Going to order the remaiing steel for the frame today -  So next weekend I can hopefully finish tacking it all up, just in time for my Brother to weld it properly while he is home from Spain.
« Reply #169 on: July 23, 2012, 08:21:36 AM »
Certainly sounds like progress. Soon be on the road then Andy!
« Reply #170 on: July 23, 2012, 09:00:43 AM »
I wish!  Every little job takes so long ..... Would be nice to have it on the road this year though, we shall see ....
« Last Edit: July 23, 2012, 09:12:05 AM by andyrennison » Logged
« Reply #171 on: August 14, 2012, 08:32:13 PM »
Just reporting in Chaps. Another round of busy, busy, busy with work, but the frame progresses well. The stainless mudguard has arrived (rear wheel cover from 4x4 and looks like it will work in a treat.  If all goes well i'll take a piccy at the weekend.
« Reply #172 on: August 15, 2012, 05:22:28 PM »
I've seen those advertised on Ebay. Good idea.
« Reply #173 on: August 15, 2012, 10:11:58 PM »
I used a stainless wheel cover for my rear guards, cut it into the required lengths then trimmed them with 5mm round bar to give a nicer edge as the existin edge was a little sharp although you couldnt cut yourself on it  Smiley
« Reply #174 on: August 16, 2012, 08:30:05 AM »
Some people here in Essex have them but I`ve always thought they wobbled a bit too much when going down the road, and that was after being strengthened a bit.
dobber
« Reply #175 on: August 18, 2012, 07:13:05 PM »
moved on a bit rennie since i last saw it...
        can i have it in 20 Min's?
« Reply #176 on: August 22, 2012, 08:58:20 PM »
The beast arrived. Been messing with it. Away on hols at the the moment, will put some pics up when I get back. Got a few days on the build when I return before I go back to work. Whoooooooo hoooooooo
« Reply #177 on: September 02, 2012, 09:08:14 PM »
Moved things on a little this past view days. Here are some pics (for Merv!)
The rear "roll bar" is c**p - not at all what I want and is coming off.
« Reply #178 on: September 02, 2012, 09:11:08 PM »
The rear end is taking shape
steven brock
« Reply #179 on: September 02, 2012, 09:14:26 PM »
What's all the steel tube work at the back for? Bench seats? looking good
