June 04, 2026, 03:57:47 AM *
Pages: 1 ... 8 9 [10] 11 12 ... 48
Author Topic: Rennies Trike  (Read 349811 times)
« Reply #135 on: July 18, 2012, 08:20:46 AM »
Yes, all the joints will be gusseted, with one longer edge to make a swoopy look. Waiting for the steel, I ordered 3mm, will that be enough ?
one arm bandit
« Reply #136 on: July 18, 2012, 01:09:37 PM »
i did all my gusseting from 10awg(3mm) its plenty, andy does the fan spin the right way... as most mount behind the rad and desperse the heat back toward the engine, i know they can be wired to spin either way but if wired to spin anti clock wise mine clicks as its not meant to spin that way Tongue
« Reply #137 on: July 18, 2012, 01:20:37 PM »
Hi, the fan is made to rotate either way so that will not be a problem (I tried it as well).  Good news to hear I got the 3mm right, as I really have no clue to any of this.  I have run out of dosh to finish the frame, so I'm using up all the stuff I have to keep the build moving till I get some more money Smiley
skiprat
« Reply #138 on: July 18, 2012, 01:36:26 PM »
ideally the gusset should be about the same thickness as the tube wall
and remember to fit the gusset to the side/edge of the tubing, not along the centre line of the tube
so if you cut the tube and gusset thru, you would have a _O not a -O
« Reply #139 on: July 18, 2012, 01:40:05 PM »
Ah, Right. It is the same as the tube, I guessed at that being right. I must admint I would have put it along the centre line. Thanks for that advice. Do you know why it is done that way ?
« Reply #140 on: July 18, 2012, 01:42:25 PM »
I was going to ask the same question
one arm bandit
« Reply #141 on: July 18, 2012, 02:14:57 PM »
it could break away or crush easier if in the center and destort the tube if you know what i mean Wink
« Reply #142 on: July 18, 2012, 02:19:38 PM »
Ah, I see. In the centre it will be trying to crush the tube, on the outside it will be trying to rotate it.
steven brock
« Reply #143 on: July 18, 2012, 05:16:00 PM »
On my next laser cutting run I can get some triangles/gussets cut for ya .. jus need a sketch or I'll just cut same as mine .. Smiley
« Reply #144 on: July 18, 2012, 05:32:54 PM »
Hi Steve
what are yours like and how much would you charge as I'm going to need a few
« Reply #145 on: July 18, 2012, 06:21:02 PM »
Cheers. Not sure what I will need yet, as there are lots of angles in this due to the curves etc. I'll make up some cardboard templates Smiley
steven brock
« Reply #146 on: July 18, 2012, 06:56:20 PM »
I found it didn't really matter to much on the shape as could move it about when I welded but yeah templates are good , perhaps post them to me and I'll sketch them up and add onto the next laser run , postage plus beer will do Smiley
« Reply #147 on: July 18, 2012, 07:10:55 PM »
Fantastic !
« Reply #148 on: July 18, 2012, 07:50:08 PM »
so my frame is totally wrong ,,,,?  Roll Eyes
steven brock
« Reply #149 on: July 18, 2012, 07:53:33 PM »
Mines 1/8 inch in on the tube I thought that was best... Ummmm
