April 17, 2026, 10:14:26 AM *
Pages: 1 ... 10 11 [12] 13 14 ... 85
Author Topic: zakboys new trike convertion project  (Read 369099 times)
Cabman77
« Reply #165 on: October 12, 2011, 08:06:07 AM »
there`s no doubt about it, the old Viagra looks a bit on the small side as a bike, but it just jumps out at you as a trike....................hhhhhhhhhhhmmmmmmmmm...................................I know a bloke down here in Essex with a really ratty viagra....................and he`s having big problems riding now too.......................................hhhhhhhhhhhmmmmmmmmmmmmm  Grin Grin Grin Grin
zakboy
« Reply #166 on: October 12, 2011, 08:19:38 AM »
Trike it cabby  Wink
Cabman77
« Reply #167 on: October 12, 2011, 08:22:12 AM »
not before a certain ladies is finished or you may never hear from me again  Grin Grin Grin Grin
« Reply #168 on: October 12, 2011, 08:28:31 AM »
hi cabman.should i ask hows the flooring coming along   Roll Eyes Roll Eyes
dobber
« Reply #169 on: October 12, 2011, 09:31:24 AM »
kinda wish i had started a conversion one for my first project zakboy, seem to see quick results.. ground up builds seem long term even though i have plenty of room. outside builds must be a nightmare..
        can i have it in 20 Min's?
trev
« Reply #170 on: October 12, 2011, 10:18:18 AM »
proper tidy mate,well done.
Cabman77
« Reply #171 on: October 12, 2011, 10:18:43 AM »
ssssssshhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!
I have got an excuse though, I`ve been really rough for the past couple of weeks, could barely move at times. I`ve even missed three very important meetings because I was so bad. So there  Grin Grin Grin Grin
dobber
« Reply #172 on: October 12, 2011, 10:47:16 AM »
zakboy, what do you put on the plate where the axel sits when the u bolts go round.
zakboy
« Reply #173 on: October 12, 2011, 10:52:21 AM »
i think now i have got a trike to use,once the xs850 is done i a may just do a reliant as there would be no rush to get it on the road its just the paper work and msva that puts me off custom builds , bolton convertion,s are ok and i can think of lots of advantage,s to boltons especially when done with adjustment  Wink
zakboy
« Reply #174 on: October 12, 2011, 11:15:04 AM »
i weld the plates so they are just proud of the frame underneath so thay are actually touching the axle and the frame tube is just sitting above the axle tubes or near enough so that i can make and place a square of rubber underneath the mounting plate more or less rubber template of the mounting plates so just to lift the frame of the axle so the rubber on the mounting plates is the only contact with the axle just helps to cut down on any vibration you may other wise get though the frame,  i don't put any thing on the unbolts all though you could thread rubber tube over them and just cut it off where the treads are they then just go round the axle from underneath the threaded part then comes up though your holes in the plates and the nuts are then on top of your mounting plates
« Last Edit: October 12, 2011, 02:54:19 PM by zakboy » Logged
zakboy
« Reply #175 on: October 12, 2011, 11:16:01 AM »
Thanks trev,all the best zak
zakboy
« Reply #176 on: October 14, 2011, 02:41:30 PM »
got rear lights sorted today used some slim line leds ,not far off being ready for mot
zakboy
« Reply #177 on: October 14, 2011, 02:42:31 PM »
thebigdogsix
« Reply #178 on: October 14, 2011, 03:34:27 PM »
Think you might want to swap one of the indicators around zac  Smiley
zakboy
« Reply #179 on: October 14, 2011, 03:56:40 PM »
well spoted BD i realy had not noticed that, its just a matter of turning it up the other way will sort that tommorow cheers  Smiley
