February 08, 2026, 02:30:06 PM *
Pages: [1] 2 3 ... 85
Author Topic: zakboys new trike convertion project  (Read 353981 times)
zakboy
« on: September 01, 2011, 04:47:18 PM »
hi all, well back again nearly twelve months after starting the first project, starting this project with out purchasing the bike yet but can start making the rear end with out having that as i do know what bikes i have in mind and what i need to do to get the rear frame started to fit any of the ones i have in mind just waiting to drop on a low mileage bike at a reasonable price eg intruder,shadow, vn, magna etc and not forgeting the good old virago,...... all though not a custom bike i have not ruled out the xj but would have to change tank and seat and get it more cruiser style.
« Last Edit: September 01, 2011, 05:47:47 PM by zakboy » Logged
stumpy
« Reply #1 on: September 01, 2011, 04:49:54 PM »
get on with it mines in for mot tomorrow
zakboy
« Reply #2 on: September 01, 2011, 04:59:21 PM »
zakboy
« Reply #3 on: September 01, 2011, 05:02:29 PM »
Ok going to use a reliant axle this one was courtesy of stumpy (thank you stumpy) its an A stamp axle 3.23/1 so today thought i would start with the axle by striping it down removing and checking the inners,then remove all brackets,clean the tubes back,remove hubs from inner shafts and clean back,will get the diff casting sand blasted when but back together
zakboy
« Reply #4 on: September 01, 2011, 05:06:19 PM »
striped down and brackets ground off
zakboy
« Reply #5 on: September 01, 2011, 05:07:56 PM »
tubes cleaned back
zakboy
« Reply #6 on: September 01, 2011, 05:09:31 PM »
hubs removed and cleaned back
« Reply #7 on: September 01, 2011, 05:11:36 PM »
and what did you do after lunch  Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
zakboy
« Reply #8 on: September 01, 2011, 05:31:06 PM »
That was affter lunch Mike  Grin
zakboy
« Reply #9 on: September 01, 2011, 05:41:27 PM »
will be going with MM disc convertion with this project to, worked well with the virago with landrover master cylinder.
stumpy
« Reply #10 on: September 01, 2011, 05:52:23 PM »
you jammy s**te how did you pull those hubs
zakboy
« Reply #11 on: September 01, 2011, 06:48:17 PM »
bicycle pump in the breather hole  Grin Grin Grin
zakboy
« Reply #12 on: September 02, 2011, 12:36:58 PM »
well took the diff housing to be sand blasted today ready for polishing, cleaned all iner diff housing and internals,then reasembled,need to order some calipper mounting plate,s next for the MM disc convertion,will be picking up tube for rear frame on monday
zakboy
« Reply #13 on: September 02, 2011, 12:37:56 PM »
« Reply #14 on: September 02, 2011, 01:56:23 PM »
have you got a ,tame/pet,, sand blaster around the corner  Smiley Smiley Smiley
