April 17, 2026, 10:00:43 AM *
Pages: 1 ... 69 70 [71] 72 73 ... 85
Author Topic: zakboys new trike convertion project  (Read 369081 times)
zakboy
« Reply #1050 on: October 31, 2012, 10:55:34 PM »
are you cables custom made or off the shelf?
thats an off the shelf reliant handbrake cable witch is a one piece cable i prefer to chop it a and use as a two piece
« Reply #1051 on: October 31, 2012, 11:01:54 PM »
So where did you get the end fittings?
zakboy
« Reply #1052 on: October 31, 2012, 11:03:23 PM »
they come with the cable
« Last Edit: October 31, 2012, 11:05:22 PM by zakboy » Logged
« Reply #1053 on: October 31, 2012, 11:08:18 PM »
Ahh. Right-o, (never had a brand new Reliant cable).
Al
« Reply #1054 on: November 01, 2012, 04:12:51 AM »
kev
what mark is this swinging arm now
everyone seems to get better and better
hows the hip
« Reply #1055 on: November 01, 2012, 06:23:02 AM »
Agree with Al about the swing arm, one suggestion though, if you're keeping the old axle tubes I'd reinforce the areas the u bolts clamp on.
those tubes are really thin walled for an axle (about 2.5mm) and easily crushed. Mine were bent slightly so i replace with thick wall cds.
zakboy
« Reply #1056 on: November 01, 2012, 09:01:19 AM »
kev
hows the hip
lol not sure what mark Al but there all very much a like i think some times it depends what bike your doing that dictate's if you need to do something diffrent on the new swingarm  the hip is s**t at the moment put my foot in a pot hole when walking the dog twisted it and now I'm back to square one on crutches that's why its a bit slow round hear at the moment with not a lot getting done  ;)lol what happend to the virago project
« Last Edit: November 01, 2012, 04:32:54 PM by zakboy » Logged
zakboy
« Reply #1057 on: November 01, 2012, 09:24:51 AM »
i do see where your coming from on the axle tubes,the only prob i see with reinforcing the area around the ubolts is that if i was to weld in some reinforcement i also risk distorting the tubes they seem to bend very easily when welding to and its a question if there 2.5 thick in places i do shy away from welding to reliant axle tubes in any form the only way if i was worrying to much about this is to make new tubes from scratch.
« Reply #1058 on: November 01, 2012, 01:19:03 PM »
Zak if you get some tube, that will sleeve over the axle tubes cut a piece 2"to 3" wide like a big end shell,
place it where the u-bolt will sit, tack it to the axle on the four corners then clamp on that.
zakboy
« Reply #1059 on: November 01, 2012, 04:26:34 PM »
i would probably risk that hunter, but iv been thinking since this morning that reinforcing this area really would not benefit me because the u bolts are not that tight they would crush the tubes, because i mount the frame on vulcanised rubber and use the same on the radias of the ubolts, so when the ubolt are tightened theres no steel to steel at the mounting points, and because of the rubber tightening the ubolts to the point that the rubber is not full compressed is tight enough and because i use nylocks on the ubolts the nuts to date have never worked loose Smiley
« Last Edit: November 01, 2012, 04:28:58 PM by zakboy » Logged
zakboy
« Reply #1060 on: November 02, 2012, 02:19:24 PM »
 Smiley
zakboy
« Reply #1061 on: November 02, 2012, 02:20:20 PM »
 Smiley
zakboy
« Reply #1062 on: November 02, 2012, 02:20:49 PM »
 Smiley
zakboy
« Reply #1063 on: November 02, 2012, 02:21:25 PM »
 Smiley
zakboy
« Reply #1064 on: November 02, 2012, 02:22:09 PM »
 Smiley
