April 23, 2026, 01:45:16 PM *
Author Topic: painting pin stripes  (Read 4049 times)
hornet6
« on: July 14, 2013, 07:22:00 PM »
Hi. I,me in the process of painting my mudguard and tank on my little gs 500,and thinking about doing some pin striping on the tank. The base coat is on the tank,which is a metallic silver. This may seem like a daft question....once the tank has been masked off,and the stripes painted on...how long do I leave the masking tape on ? Do I have to wait until the paint is fully dry, or can I peel it off after a couple of hours once the paint is starting to go a bit tacky ? Thanks.
no projects ever finished
« Reply #1 on: July 14, 2013, 08:50:31 PM »
If you peel it off after about ten minutes, you shouldn't end up with a hard edge to it.
If you are using enamel paint for the pinstripe, remember it needs to go on OVER the clearcoat, as it'll pickle otherwise
hornet6
« Reply #2 on: July 14, 2013, 09:00:39 PM »
No,not using enamel paint...just using rattle cans and spraying them on.
« Reply #3 on: July 15, 2013, 06:20:25 AM »
Yeah, ten minutes then remove tape then. It just gives you less of an edge to try and bury under the clearcoat.
hornet6
« Reply #4 on: July 15, 2013, 08:17:21 PM »
Ok thanks....will try and get some photos on maybe next weekend of the result.
hornet6
« Reply #5 on: July 17, 2013, 07:23:12 PM »
Ive put my first stripe on...and it looks pretty  good for a non painter/sprayer. When its all dried off,do i have to give it a very light buffing with fine sandpaper before clear coating,,,making sure not to rub the stripes off ?
« Reply #6 on: July 17, 2013, 11:56:17 PM »
Can do, but if its thin enough, you should be fine!
hornet6
« Reply #7 on: July 18, 2013, 06:09:09 PM »
There is a slight edge on the stripping so I may have to rub that down a tad.
