Technical Section => Trike Tech => Topic started by: yoda on August 07, 2005, 10:32:51 AM
Title: SU Carb Needle finder program
Post by: yoda on August 07, 2005, 10:32:51 AM
WinSU is a fantastic SU Carb Needle finder program
Follow link for more info
http://www.bikerlifestyle.co.uk/tech/winsu/winsu.htm
Yoda
Title: Re: SU Carb Needle finder program
Post by: Manky Monkey on August 07, 2005, 12:57:31 PM
Hmm, that could come in handy for us Reliant owning chappies.
Post by: wink100e on August 11, 2008, 04:28:39 PM
HI  all its been a while, (had the ex on my case) and been racing the robin so the trike parts got canibalised,
heres another link which you can compare SU needles on.
http://www.mintylamb.co.uk/suneedle/
Post by: VALLEYSBOY on August 11, 2008, 04:38:31 PM
Taaaa ;D um and welcome again :)
Post by: TwistedPatience on August 11, 2008, 04:42:25 PM
Yo! wink100e give us a shout when your next racing not been yet and your only up the road a bit.
Post by: wink100e on August 11, 2008, 05:07:04 PM
HI next race is BANK HOL MONDAY 25th, at MENDIPS raceway, shipham, A38 south of bristol
http://www.apwd.co.uk/joomla/index.php?option=com_frontpage&Itemid=1
JUST RELISED THE ROBINS WILL BE DOING A FIGURE OF 8 , better make sure the belts are done up tight
just to add a bit more fun there will be CARAVAN BANGER at end of day
Post by: Manky Monkey on August 11, 2008, 07:43:04 PM
Hiya Winky,
As we seem to have a major bias on this 'ere site towards Reliants, it'd be fantastic if we could have a race report & some piccies -any chance?
Post by: wink100e on August 25, 2008, 12:20:24 AM
have we found any gains from this site
Post by: sid on November 11, 2008, 01:05:02 AM
my son use to race mini's in grass raceing, i have a book some were that tells you what number carbs take what size's jets and needles would that be any help if i could find it.
Post by: Manky Monkey on November 11, 2008, 05:54:36 AM
I'm sure it would Sid, cheers.
Post by: fifer on November 26, 2014, 05:16:44 PM
I have made a spreadsheet comparing the usual jet needles { Spring Type } found on standard Reliant motors .
Needle Code ; AAT is the normal needle found on most 9.5 compression 850cc engines .
I have compared the following needles against the AAT .
Needle Code ; AEB is the needle found on most 10.5 compression 850cc engines often referred to as Yellow Tops .
Needle Code ; AAC is possibly the needle for 8.5 compression 850cc engines ?
Needle Code ; ABS is possibly the needle for 7.5 compression 850cc engines ?
Needle Code ; ABQ is an unknown needle I have in my collection of used carb spares so it has come out of a Robin or Rialto I have had ?
https://sites.google.com/site/fifersrelianthintstips/carb-su-carb-jet-needle-spring-type-comparison-of-4-common-needles
(http://i423.photobucket.com/albums/pp316/fifer3w/SUCARBJETNEEDLESPRINGTYPE_zpsc461e7d0.jpg) (http://s423.photobucket.com/user/fifer3w/media/SUCARBJETNEEDLESPRINGTYPE_zpsc461e7d0.jpg.html)
