Title: Side lights/headlamps Post by: RODeo on June 19, 2011, 03:14:33 PM Stupid Q's.........
I have front side lights on the front of the rear guards,do I still need them in the headlight(s) ? If I am running 2 headlamps side by side,should they be wired so that both are switchable to dip and both on main,or does one have to be dip and the other main ? Seen this on some sport bikes I think. Title: Re: Side lights/headlamps Post by: ByzMax on June 19, 2011, 04:25:36 PM You don't need a head lamp marker if as you have forward facing markers on your mudguards.
I will say that they need to be bright! (Not for the regulations) Because if you ride at night oncoming vehicles will find it hard to see them and assume your a bike with the obvious consequences. Twin headlamps must be one dipped one main for the SVA if they are closer than 500mm (I think) edge to edge Unless you mount one above the other. If your Trike is more than 1700mm wide but less than 2000mm you must have twin headlamps and the outer edge of the illuminated surface of each lamp should be no more than 400mm inside from the widest part of the vehicle. They can then operate together. ;D Title: Re: Side lights/headlamps Post by: RODeo on June 19, 2011, 07:47:13 PM Thanks Iain.
Title: Re: Side lights/headlamps Post by: ByzMax on June 19, 2011, 08:41:52 PM Your welcome ;D
