Title: warning re rustoleum paints. Post by: RODeo on May 08, 2011, 07:59:14 AM Hi All
I bought some dark blue rustoleum spray (min order of 6 cans!)Have sprayed my frame ,waited a few days .rubbed down ,recoated the dodgy bits ,it now looks excellent. I also ordered a 1 litre tin of rustoleum for brushing on,same colour and RAL number . I opened it today to hand paint parts of the engine ,and found that altho' it has the same RAL number on the tin it just isnt anything like the dark blue of the spray.Its more of a mid blue,sort of darkish baby blue! I thought this stuff could only be got from Rustoleum direct,but apparently my local paint people have a mixing machine for it at another branch, which is where I got mine from.I asked them several times whether it was a bona fide Rustoleum machine ,and they assured me it was. Obviously theres a part of the mix they havent put in OR the machine isnt delivering the correct quantities!So beware ordering at different times ,best to buy all from one batch.Going back to Kent Blaxill tomorrow to get my money back. Title: Re: warning re rustoleum paints. Post by: Cabman77 on May 08, 2011, 08:32:11 AM .Going back to Kent Blaxill tomorrow to get my money back. [/quote Go get `em Rod >:( >:( >:( >:( Title: Re: warning re rustoleum paints. Post by: Manky Monkey on May 09, 2011, 12:59:46 PM I've heard of Rustoleum, but never used it. Is it like Hammerite? Hammerite seem to have changed their formula over the years -doesn't seem to cover half as well as it used to. Probably had to remove various chemicals to comply with European regulations or summat. I assume it's oil based. I didn't realise you could mix it like normal paint.
Title: Re: warning re rustoleum paints. Post by: spanners on May 09, 2011, 02:19:40 PM if i ever had to buy a rattle of paint i allways bought two just in case so over the years i ended up with a very usefull shelf full of cans/part cans of allsorts ,,,
but they dont keep forever they go rusty and pop normally on the shelf above you when youre very busy trying to concentrate on something ::) ::) Title: Re: warning re rustoleum paints. Post by: voodoo on May 09, 2011, 04:11:36 PM Have the same problems with a lot of the stuff I use, I always order more than i need because 90% of the time if you have to buy some more of it then it wont match...Hope you get it sorted...Voodoo....
Title: Re: warning re rustoleum paints. Post by: Cabman77 on May 10, 2011, 07:55:49 AM but they dont keep forever they go rusty and pop normally on the shelf above you when youre very busy trying to concentrate on something ::) ::) ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D |
