Technical Section => Trike Tech => Topic started by: gpz on August 18, 2010, 06:44:08 PM
Title: battery box
Post by: gpz on August 18, 2010, 06:44:08 PM
might be a silly question but what do i need in my battery box apart from battery starter solenoid and fuse box .and am i right that heavy duty cable comes from the battery to the starter solenoid then to the starter.if so is there a right and wrong way for the starter solenoid cant see any marking on it any help appreciated as where electric is concerned i havent a clue
Title: Re: battery box
Post by: tbone on August 18, 2010, 07:24:32 PM
Apart from what you`ve mentioned, you may also want to stick your flasher and hazard units in there.
The solenoid is just a switch, electricaly operated, but just a switch, doesn`t matter which terminal goes to what.
As you say, its Battery to solenoid, solenoid to starter. Then the exciter terminal on the solenoid is connected to the start button/switch.
Post by: Cabman77 on August 18, 2010, 08:37:18 PM
You have such a lovely way with words T Bone  ;D ;D
Post by: gpz on August 21, 2010, 09:52:24 AM
thanks for that TB another question i am looking for an indicator flasher unit do i need one with 2 or 3 pins and what is the difference between 2 and 3pin units, again any help appreciate
Post by: tbone on August 21, 2010, 05:21:28 PM
Thank you  ;D
Post by: tbone on August 21, 2010, 05:41:12 PM
Either will do the job but will need to be wired up differently.
There are also 2 different types of 3 pin unit, the older electro-mechanical type or the electronic type, again either will do but the wiring is completely different.
Lets deal with the 2 pin unit first, the terminals on these are marked B & L.
B is the supply (+12v in)
L feeds the switch
The Electro-mechanical 3 pin units are usualy marked X, P & L
X is the supply
P feeds your indicator warning lamp
L feeds the switch
The electronic units will be marked 31, 49 & 49a
49 is the supply
49a feeds the switch
31 goes to earth
note the absence of indicator warning lamp. This unit is usualy used when you have 2 warning lamps, 1 for each side, where the feed for these is picked up from the switch output.
There is a 4 pin electronic version of the above, with an additional terminal marked C. The C terminal feeds the warning lamp.
