Title: Wiring etc........Couple of Q.s Post by: RODeo on August 02, 2010, 08:48:13 AM Hi All
Blonde moment here ...(or grey in my case! ;D)..............Never wired hazards before ,only added the system to classic cars..... Hazard wiring...Will I only need one wire plus an earth to each indicator,and I presume a hazard relay does the indicators as well? Engine bolt threads.......Its soon time to pull the engine for the final tart up . Anyone know what thread the bolts are for the bellhousing ? UNF? UNC? or summat else? Also the thread for the g/box top plate bolts and the head bolts?Im going to do all bolts /nuts in s/steel. Thanx Title: Re: Wiring etc........Couple of Q.s Post by: tbone on August 02, 2010, 09:37:59 AM Morning Rod, nice to hear your progressing...
Head Studs are 3/8" UNC into the block and 3/8" UNF on the other end Bellhousing Studs are 5/16" UNC into the Bellhousing and 5/16" UNF on the other end Gearbox top plate bolts are 1/4" UNC Are you using a combined Indicator/Hazard flasher unit or 2 seperate ones? Title: Re: Wiring etc........Couple of Q.s Post by: triker_Chewie on August 02, 2010, 10:45:04 AM ufc? ;D
Title: Re: Wiring etc........Couple of Q.s Post by: Cabman77 on August 02, 2010, 11:26:55 AM http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180386802413&ssPageName=STRK:MEWAX:IT
This might help take the pain out of the hazards for you Title: Re: Wiring etc........Couple of Q.s Post by: RODeo on August 02, 2010, 02:27:57 PM Thanks for thread info TB.
I had seen those hazard kits ,but 'cos Im doing everything from scratch, I havent got an existing set up to splice in to. ..............hmmmm ...just had another look at those kits..think I may get one then adapt it to fit . Title: Re: Wiring etc........Couple of Q.s Post by: twistgrip on August 02, 2010, 03:02:07 PM Bit more expensive, but does provide a nicer handlebar switch.
http://indicator-buzzers.co.uk/index-3.php?region=uk I'm in the same boat - gonna sort out front and rear indicators first, then splice this kit in afterwards. David |
