Technical Section => Trike Tech => Topic started by: Bozza on June 08, 2010, 05:04:28 PM
Title: Reliant axle conversion plates- bolt size?
Post by: Bozza on June 08, 2010, 05:04:28 PM
Does anyone know the size of set screw / bolt required to fit the mounting plate (for disc conversion) to the axle tube on a Reliant axle please?
Does it have a nut on the end or is it threaded into the tube?
Thanks
Bozza
Title: Re: Reliant axle conversion plates- bolt size?
Post by: steven brock on December 06, 2010, 09:38:07 PM
i used 4 off 5/16ths bsf socket headed cap screws and spring washers, had to tap out thread first because of the crud!
