Technical Section => General Tech => Topic started by: TwistedPatience on February 18, 2010, 05:48:41 PM
Title: HELP
Post by: TwistedPatience on February 18, 2010, 05:48:41 PM
Need help fast, My GS850 has decided to run like crap in the wet, replaced plugs and air filters, same problem but noticed tonight that not long after start up the exhausts on cylinders 2 and 3 are glowing red hot any ideas?
Title: Re: HELP
Post by: cunningplan on February 18, 2010, 06:13:28 PM
running to lean!!!! check the carbs
Title: Re: HELP
Post by: TwistedPatience on February 18, 2010, 06:22:48 PM
Thanks Tony that's what I thought but needed second opinion.
Title: Re: HELP
Post by: trikerpete on February 20, 2010, 09:56:45 PM
doc, what carbs and filters are you running?
Title: Re: HELP
Post by: TwistedPatience on February 21, 2010, 05:51:28 PM
Standard Carbs and S&B filters + air correction kit.
Title: Re: HELP
Post by: ByzMax on February 23, 2010, 07:26:16 PM
Get the carbs off and give em a blow through..  ;)
Title: Re: HELP
Post by: cunningplan on February 23, 2010, 09:15:07 PM
I bet thats what you say to all the ladys  ::)
Title: Re: HELP
Post by: gsxrsam on February 24, 2010, 08:06:39 AM
also check ignition cover for water ingress...
Title: Re: HELP
Post by: TwistedPatience on February 24, 2010, 06:56:41 PM
Turns out that the new air filters are less restrictive than the S&B's that i had and was making the engine run lean, it didn't occur to me that there would be that much of a difference between air filters of a similar type.
So I have replaced the old filters and it's back working fine again, oh and one of the new plugs was faulty and an HT lead was shorting out.
