Technical Section => General Tech => Topic started by: brock on December 24, 2009, 02:36:30 AM
Title: When you absolutely, definitely, must get something finished.....
Post by: brock on December 24, 2009, 02:36:30 AM
  ........ because you are behind your self imposed schedule and stuff to be done is stacking up, take a break, step back, slip another little fun project into the mix. It won't help but it's a bit like scratching an itch, you've just got to do it.
Title: Re: When you absolutely, definitely, must get something finished.....
Post by: brock on December 24, 2009, 02:38:39 AM
    all from 2 mil stainless, a bugger to form but quite pleasant to weld
Post by: brock on December 24, 2009, 02:46:21 AM
   Hope to fire it up over the holiday, they're meant to have the ability to waken the dead at high throttle settings, we'll see. An alternative scenario is that nothing happens, further research suggests that they are really quite sensitive to changes in the volume of the tube sections and I have just worked from a photograph and then used what I had laying around, still, the potential injury forcast is possible to real with severe threatened later, should be fun, I'll let you know
Post by: brock on December 24, 2009, 02:52:10 AM
   The igniter box took a bit of thinking about, involving several relays operating each other, I thought that ALL relays followed a common numbering system, not so, I got it in the end although the plug gap is now opened up so far that it seems to prefer arcing to the side, I suspect that it will still do the job, more as it happens
Post by: toad on December 24, 2009, 06:09:25 AM
neighbors are gonna love you the noise they make are unbelievable ;D ;D ;D
Post by: Manky Monkey on December 24, 2009, 09:19:40 AM
Am I the only one here who hasn't got a clue what you're making there big bro?
Post by: gazzagood on December 24, 2009, 11:28:28 AM
no Andy. theres me i ant got clue wot it is either.gaz
Post by: toad on December 24, 2009, 11:31:19 AM
i wont spoil it but the germans used them in ww2 ;) ;D
Post by: Manky Monkey on December 24, 2009, 11:32:17 AM
He's building a Panzer tank?
...actually, that wouldn't really suprise me.
Post by: toad on December 24, 2009, 11:33:43 AM
nope its louder than one o them ;D
Post by: Hagar on December 24, 2009, 12:59:48 PM
Pulse jet  ?  .............
  ..  Hagar  ..
Post by: Simple Simon on December 24, 2009, 01:15:15 PM
Could that possibly be used to melt your way through the snow?? ;D
Post by: TwistedPatience on December 24, 2009, 01:51:18 PM
Melt...! vaporise more like. ;D
Post by: Simple Simon on December 24, 2009, 05:51:05 PM
 :o ??? 8) ;) ;D
Post by: hornet6 on December 24, 2009, 05:57:42 PM
i thought it was a doodle-bug
Post by: Firery Fred on December 24, 2009, 07:30:27 PM
Nope I'm beat also  ???
Post by: hunter on December 24, 2009, 09:02:09 PM
I think that may need a firearm certificate. ;D
Post by: Simple Simon on December 24, 2009, 10:40:33 PM
No, it's armless that is ;) ;D
Post by: hunter on December 24, 2009, 11:34:09 PM
it must bee a hair dryer then.
Post by: smallhog on December 25, 2009, 03:20:21 PM
One of those exhaust flame throwers?  :o
Post by: TwistedPatience on December 31, 2009, 02:35:36 PM
Brock are you going to tell 'em what it is?
Have you got it working yet?
Post by: Clive on December 31, 2009, 05:28:03 PM
Tell me, tell me, tell me, tell me, tell me, tell me, tell me, tell me, tell me!!!!!!!!!!
Post by: TwistedPatience on December 31, 2009, 06:39:33 PM
It's Brocks baby I'm keeping quiet.
Post by: brock on December 31, 2009, 10:45:12 PM
   I had an unexpected break in the form of a few days away in Old London Towne courtesy of Mrs B so nothing has been done to anything for a week, however, the house is full of outlaws tomorrow and being an unsociable git I'll melt away like a wraith, and indeed wraith to the thed and give it a try, maybe photos tomorrow, or hospital !
Post by: Manky Monkey on December 31, 2009, 10:48:11 PM
I'll watch for the glow in the sky over Marlborough then.
Happy New Year big bro.  ;)
Post by: brock on January 02, 2010, 06:30:20 PM
  Got bored taking the race car apart to alter the transmission ( again) tonight so had a little play with it. As most have guessed, it is actually a high speed hair dryer, not having a handy volunteer we just set it up on the ground to test it.
Post by: brock on January 02, 2010, 06:35:23 PM
   Ignition on, air on, gas on, big bang and flash of flame, then nothing. Back the gas pressure off a bit and try again, ooooh, it runs, after a fashion.
Post by: brock on January 02, 2010, 06:42:56 PM
   It will run with the ignition turned off, which is good, but not without the forced air feed which isn't. More research needed, from the extent of the heat pattern on the body it looks like I may have made the combustion chamber too long, it was all a bit of a guess at the sizes and some development was bound to be needed, but it's a start. A few shots with the flash turned off, the camera is very susceptible to shake in low light as you may be able to discern ( ! ) but they do show the heat patterns on the body
Post by: Manky Monkey on January 02, 2010, 06:54:22 PM
That's one serious hair dryer!
So it's a jet engine then. A "pulse jet" -what exactly does that mean? And what does one do with one's jet, now you've made it? How much thrust would that generate, (I'm sure you've already worked it out :) ). Enough to power ...? a bike? A go cart? A double decker bus? How would you mount it in a vehicle without melting everything around it? Can you regulate the power, or is it literally point & fire? Have you managed to burn down the workshop with it yet?
I'm so glad insanity doesn't run in our family, big brother!   :P
Post by: Blackpig on January 02, 2010, 07:25:05 PM
   "I'm so glad insanity doesn't run in our family, big brother!"
There's still time Andy, Brocks didn't kick in until he reached 49 ;D
Post by: TwistedPatience on January 02, 2010, 08:23:51 PM
"I'm so glad insanity doesn't run in our family, big brother!" ...................Sorry but I think it does Andy!
(Pop, two trikes and a Charger, and to top it off you work for the post office)
Who's Insane? ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Barking Mad ;D
Post by: Manky Monkey on January 02, 2010, 09:20:05 PM
Yeah, fair comment.  :P
Post by: DIZZY on January 03, 2010, 06:47:22 PM
Is it a leaf blower? i thought it was a trike exhaust system naaaaaaaa giz a clue? the germans used them in the war? is it to do with gas?
Post by: Manky Monkey on January 03, 2010, 07:58:21 PM
It's a jet engine! Pay attention at the back!
Obviously we all knock up such playthings when we're having a slack day -don't we?
Post by: TwistedPatience on January 03, 2010, 08:06:02 PM
Yep!
Post by: andbolt0 on January 03, 2010, 09:50:13 PM
thought it mite be somthin like this http://www.youtube.com/watch?v=ykF3TUTI2hU
Post by: brock on January 04, 2010, 07:00:16 AM
    :D, no it's one of these :-
http://www.youtube.com/watch?v=h6qSCRcaxzM
    very susceptible to gas pressure changes, I have some ideas about that and will try to find the time in the week to have a play.
    On the subject of the big potato guns, Osma/Wavin plastic soil pipe is too brittle to withstand large charges, you need the expensive stuff if you don't want to be peppered with lots of nasty little stinging bits of plastic  ::)
Post by: cunningplan on January 07, 2010, 08:08:20 AM
All that time and effort and you could have gone to B & Q and got a weed burner ;D
Come on Brock, get some work done (Thats if you can get to the shed)
Post by: brock on January 09, 2010, 07:54:52 PM
   modified the gas inlet today, junked my lovely stainless steel fabricated injector and ran the open feed pipe straight into the inlet tube, may try to run it again tomorrow, depends if I can thaw the tool box locker on the truck to get at the stuff I need. It may not currently run very well but it is a pretty colour
Post by: Manky Monkey on January 09, 2010, 08:33:56 PM
Use the jet to thaw out the van?
Post by: brock on January 09, 2010, 08:42:05 PM
   Run the jet to thaw the locker I need to get into to get the stuff I need to run the jet ? I'll have to think about that ! Still fairly chilly out
Post by: Manky Monkey on January 09, 2010, 08:48:36 PM
Ah, I see the problem.  :P
What's the car in the snow?
Post by: brock on January 10, 2010, 02:20:11 AM
   cunningly disguised trike ?
Post by: cunningplan on January 10, 2010, 10:26:37 AM
NO! Nothing to do with me  :o
Post by: TwistedPatience on January 18, 2010, 08:10:23 AM
Check out this site
http://freespace.virgin.net/dyno.power/gasturbine/gasturbine.htm
Post by: brock on January 18, 2010, 07:24:49 PM
   Brilliant site, clever man. Possibly the first site I ever saved after I found what a "favorites list" was. I hadn't looked at his jets but do keep going back to look at his Nitros systems, hmmm, if only I had a spare motor, hang on, I bought one yesterday ! !, Oh dear ......
Post by: Blackpig on January 18, 2010, 08:11:10 PM
 "only I had a spare motor, hang on, I bought one yesterday ! !"
 Have you forgotton to tell me something? ???
Post by: TwistedPatience on January 19, 2010, 07:51:18 AM
OOPS in the s**te now Brock ;D
Post by: brock on February 06, 2010, 09:21:28 PM
    ;)   all is well.
 had another go with the jet, still won't self sustain without air feed, I might try cutting the inlet off and make an adjustable sliding sleeve to go over the stub and see if the length affects it
Post by: TwistedPatience on February 07, 2010, 08:37:00 AM
 ;D kool Brock.
Post by: cunningplan on February 08, 2010, 11:20:53 PM
    ;)   all is well.
We know we wont be bombed from Marlbough in the near future them brock  ::)
Post by: brock on February 09, 2010, 01:31:09 AM
   not unless I invest in a really, really long air line
