Title: granada axle Post by: hunter on December 07, 2009, 11:06:39 PM Hi all,thought it was about time i showed my face so to speak,
i registered in august but have just been reading and learning, a lot of clever people on this site. anyway down to my question,How much difference is there between the granada and sierra. physical size,ratio. Title: Re: granada axle Post by: tbone on December 08, 2009, 10:18:08 AM Simple answer.... bugger all size wise between the vehicles ;).
But the Granada also ran a 3.92:1 ratio. Drum braked vehicles all ran a 7" diff with push in type shafts, while disc braked vehicles had the option of 7" or 7.5" diffs and the shafts bolt to the diff. Title: Re: granada axle Post by: hunter on December 08, 2009, 11:11:18 AM Thanks for the reply thone.
there's a scrap yard near me that has an M plate car,the axle has discs so bolt on drivshafts, Title: Re: granada axle Post by: tbone on December 08, 2009, 11:26:44 AM Welcome aboard by the way, i forgot to say that, its my age you know ::)
Originaly the diff would have had a tag attached to one of the housing bolts, the tag would have had the ratio marked on it, but inevitably the tags vanish over time. As with most (all?) Ford diffs though, they do take the time and trouble to stamp the ratio in the gear, but that means pulling the plate off the diff to get inside. See the attached pic to tell the difference between the 2 different diff sizes. Title: Re: granada axle Post by: hunter on December 08, 2009, 12:12:03 PM thanks for the welcome tbone, and don't worry about it i'm getting the age thing myself,
if i dont hurry and get on with this build i'll forget wot i set out to do and end up with a zimmer, apart from the ratio what differance will the 7"and 71/2"make to the build. Title: Re: granada axle Post by: ROD on December 08, 2009, 01:05:06 PM Welcome to the world of mankeyisms.......... ;)
Title: Re: granada axle Post by: tbone on December 08, 2009, 06:18:23 PM No difference at all ;)
Title: Re: granada axle Post by: hunter on December 08, 2009, 08:40:27 PM I had better go and get it then,
thanks again tbone. and thanks for the welcome ROD. |
