Title: reliant starter motors Post by: brains on November 01, 2009, 03:33:37 PM any one know what type of starter I need for my 850 reliant lump . just changed the engine complete ??? with the fly wheel that came with it . fitted my original starter which was a pre engaged type (the gearbox had been drilled to suit it) the starter now does not engage the fly wheel. I have checked the teeth on the fly wheel and they are all OK. so I think i must need the correct starter ... but which model number ? can anyone help please ....
Title: Re: reliant starter motors Post by: ROD on November 01, 2009, 03:35:16 PM Maybe wrong amount of teeth on the starter dog? I think you can still buy the new dog for it .
Title: Re: reliant starter motors Post by: brains on November 01, 2009, 03:39:39 PM maybe but how do i find out what one to get as the factors dont even list the starters any more ?
Title: Re: reliant starter motors Post by: toad on November 01, 2009, 04:46:37 PM any one know what type of starter I need for my 850 reliant lump . just changed the engine complete ??? with the fly wheel that came with it . fitted my original starter which was a pre engaged type (the gearbox had been drilled to suit it) the starter now does not engage the fly wheel. I have checked the teeth on the fly wheel and they are all OK. so I think i must need the correct starter ... but which model number ? can anyone help please .... [/quote are you getting just a whizzing noise??? that could be just a flat battery. try removing the starter and wiring direct to a set of jump leads and see if it throws the dog gear out as far as im aware all flywheels are the same. Title: Re: reliant starter motors Post by: tbone on November 01, 2009, 04:49:30 PM There are only 2 options, inertia or pre-engaged.
The pre-engaged unit is used on mini`s too. who`s part number do you want for reference? Autostart A810 Bosch 0 986 020 151 or 9 004 475 314 Delco DRS3368 GKN 4091 Hella 8EA 730 207 001 Lucas LRS536 Marelli MRS525 QH FRS128 Sovereign SS810 Unipart GXE4527 Valeo VS150 XL X913368 And as a side note, I detest these modern motor factors that insist of desposing of old catalogues the second a new one is published! Title: Re: reliant starter motors Post by: spanners on November 01, 2009, 05:54:56 PM t.bone... wasn,t the inrtia starter also used on early mini,s and moggy 1000,s ive had hold of 100,s over the years but cant remember the part no,s
Title: Re: reliant starter motors Post by: brains on November 01, 2009, 06:11:17 PM thanks guys I knew you could help . I have hopefully solved the problem as the guy I got the engine from also still has the original starter . just need to pick it up thanks again
Title: Re: reliant starter motors Post by: tbone on November 01, 2009, 06:36:27 PM t.bone... wasn,t the inrtia starter also used on early mini,s and moggy 1000,s ive had hold of 100,s over the years but cant remember the part no,s Sort of....although the early mini`s did use an inertia starter its not the same as the reliant, the mounting holes are closer together, 4.5" as opposed to 5", 1098 minors use the same one though. Title: Re: reliant starter motors Post by: Manky Monkey on November 01, 2009, 07:57:34 PM Aren't the flywheels different for pre-engaged & inertia starters?
Title: Re: reliant starter motors Post by: tbone on November 01, 2009, 09:14:35 PM erm, i dunno. I cant see any reason for them to be different but......
Title: Re: reliant starter motors Post by: Manky Monkey on November 02, 2009, 08:36:45 PM I've never compared them, but remember a conversation with someone once when we were talking about how noisy the inertia type are -they engage with a great clang of metal on metal. Pre-engaged obviously sound a little more civilised when they start. Can't even remember who I was talking to, but they said if you switch to pre-engaged, make sure you swap the fly wheel too.
Title: Re: reliant starter motors Post by: morrag on November 02, 2009, 11:03:26 PM Probably meant the flywheel ring-gear, not the actual flywheel, Morrag
Title: Re: reliant starter motors Post by: snafu on November 03, 2009, 12:36:10 AM In the dim distant past I vaguely recall that the was an engine fitted with an inertia starter, with this type
of starter there is a lead on the teeth of the ring gear on the side where the pinion engages, there was a conversion to fit a pre-engaged starter that involved flipping the ring gear (in practice a new one) so there was no lead on the teeth where the pre-engaged pinion engages. Can any one remember what vehicle this was on ??? |
