Technical Section => Trike Tech => Topic started by: steve on December 24, 2008, 07:57:07 PM
Title: PCD INFO
Post by: steve on December 24, 2008, 07:57:07 PM
Just wanted to know about studs,most wheels i look at say 100mmdia.,reliant axle studs are 4"x4" a differance of 1.6mm,surely this may pose problems? would appreciate some feedback.                Thanks.
Title: Re: PCD INFO
Post by: BikerGran on December 24, 2008, 09:55:03 PM
I know nothing but I'm sure there's some info on the main site...........
Ah yes, clicky Here (http://www.mankymonkeymotors.co.uk/Tech/pcd/pcdmain.htm)
Hope what you need to know is in there somewhere!
Title: Re: PCD INFO
Post by: Manky Monkey on December 25, 2008, 12:28:35 AM
Hiya Steve,
this has been discussed a couple of times on the forum. Yes, obviously, ideally you should be using Imperial sized wheels with Imperial studs, but as you say, the difference is 1.6mm. Less than 3/4 of a millimetre per stud. A couple of fag papers worth. Bolt the wheels on & take 'em off again a couple of dozen times & the studs & wheel holes will wear more than that. If you're not happy then please don't use them, but all I can say is we've been mixing Metric & Imperial for years with no problems at all.
