Technical Section => Trike Tech => Topic started by: Watsonic on July 12, 2008, 05:08:12 PM
Title: Virago fueling
Post by: Watsonic on July 12, 2008, 05:08:12 PM
Hi can anyone HELP
I'm building a trike using a 535 Virago as a doner.I've used the engine, loom and all the origional ancilleries.
During the rebuild and test stage (Prior to restarting the engine) when the ignition and kill switch are both on the fuel pump would run for 5 seconds aprox' as it should.
But now I'm in a possition to start it the pump don't run???
I've tested the pump and with a direct 12 volt supply that runs but whe connected through the loom it don't work
Any ideas can any one shed any light???  >:(
Title: Re: Virago fueling
Post by: morrag on July 12, 2008, 10:12:50 PM
All the models I have seen of the Virago have had carburrettors, including my own 750, so I'm mystified where your fuel pump comes from? Morrag
Post by: Watsonic on July 13, 2008, 09:19:47 AM
The 535 Virago has twin fuel tanks, one in the normal place and one below the seat hence it uses a pump
Post by: klogan45 on July 13, 2008, 01:58:55 PM
A silly question may be but....have you checked the fuses and earths?
Regards
K
Post by: morrag on July 18, 2008, 10:17:50 AM
I have checked the Haynes man. and now see what you mean! the seperate fuel tank is listed as an "emergency" fuel supply, and from the wiring diag. is operated via a fuel switcxh, supplied via the engine stop/ cut off, and the fuel supplied through a petrol solenoid, held "off" when the motor is fed from the 'above engine' tank fuel.I can send you a copy of the schematic if you wish, what year is the bike? cheers, Morrag
Post by: Watsonic on July 21, 2008, 05:56:11 PM
Would realy apreciate that. Thanks :)
Title: Re: Virago fueling Wiring pic
Post by: morrag on July 21, 2008, 10:16:37 PM
Try this, although it might be a bit small!! Morrag
Post by: Watsonic on August 06, 2008, 04:41:11 PM
Thanks for the help and info.
This is what it looks like so far.
Still a way to go but getting there so far parts from 9 differant bikes have gone into this...................
Approximately 500 hrs work and a lot of 'Back Street Engineering'
Post by: Firery Fred on August 06, 2008, 06:49:46 PM
Looks good to me mate ;D ;D ;D
Post by: Manky Monkey on August 06, 2008, 07:00:41 PM
Me too. Very tidy. :)
