General Category => General Discussion => Topic started by: klogan45 on November 29, 2007, 07:34:08 PM
Title: Intruder 750
Post by: klogan45 on November 29, 2007, 07:34:08 PM
Can some one please help with a problem that's driving me and bikerpsycho mental...wibble wibble!!
Bikerpsycho has an intruder 750, the clutch went so between us we fixed it!!! Fixed being a matter of opinion. Its a hydraulic clutch. The clutch is not disengaging the drive. If you pull in the clutch lever and try to start the engine it pulls forward. I suggested bleeding the master cylinder... that did'nt work but I noticed that when you pump the lever, some small bubbles come in to the resevoir and if you pull the lever in quickly some of the fluid comes up like a little (tiny) fountain, about half an inch high. Would this be a clue that the master cylinder seals are banjaxed? It may be a very basic question but we do need a little help...Please.
We can then sort it out and get the little bugger out from under my feet sometimes. He's a good lad but you can have too much of a good thing ;D ;D ;D ( I expect he'll read this and i could be in trouble .... again ;D ;D ;D)
Thanks a lot
Regards
Keith
Title: Re: Intruder 750
Post by: toad on November 30, 2007, 09:53:11 PM
ah ha you have the trapped air syndrom i bet its a nissen master cyl fitted? its an easy cure! take the cap off and pull the lever about a dozen times and release slowly you should get a stream of very small bubbles do this 2 or three times and then bleed as normal dont worry about the small fountain in the cyl thats just the displaced fluid returning.that should cure it ;)
Post by: BikerGran on November 30, 2007, 10:20:42 PM
And if that don't work, try my infallible cure for brakes that won't firm up - bungy the lever tight to the bar and leave it overnight!
Post by: klogan45 on December 01, 2007, 05:27:33 PM
Thanks to both of you, we will try that tomorrow,if chris is'nt working or on monday. Will let you know how we get on.
Regards
K
Post by: Bikerpsyco on December 03, 2007, 03:38:57 PM
We tried but to no provail the bike still wants to pull forward so im going to have to suck up and take it to bike shop tommorrow, tried tieing the lever back and tried the twelve pumps but just the same, thanks for your suggestions but hey we cant win everything,
cheers
chris
Post by: klogan45 on December 08, 2007, 01:40:21 PM
Seals have gone in the master cylinder, oh well, will try living coasts, they've got loads down there!!
