Technical Section => Trike Tech => Topic started by: VALLEYSBOY on October 27, 2007, 11:43:29 AM
Title: carbs
Post by: VALLEYSBOY on October 27, 2007, 11:43:29 AM
hi, i now Manky has listed the su hs2 as a standard fitment, ca nthe reliant use the slightly bigger hs4? plus im assuming id have to get correct needles etc for it .
Title: Re: carbs
Post by: brock on October 27, 2007, 12:03:17 PM
circular area are deceiving, that "slightly larger" HS4 gives an increase of about 45% in cross sectional area, I would think that you would see some gains in the top end ( given correct jetting ) but noticeable losses in response. I stand to be corrected.
Title: Re: carbs
Post by: VALLEYSBOY on October 27, 2007, 05:50:34 PM
hmm ok point taken :)
