Title: Brake light switch Post by: merv on October 26, 2021, 05:22:25 PM Hi Folks I'm still around , what do people use for a brake light switch on a bike trike Title: Re: Brake light switch Post by: Olds on October 29, 2021, 06:48:14 PM Hydraulic banjo bolt pressure switch works well, or a tee with a brake pressure switch somewhere in line. Later bikes have a built in switch in the front brake lever. For the rear, mechanical switches are OK but can be prone to moisture problems and adjustment issues.
I use a banjo bolt switch for the front brakes as I used a clutch lever/master cylinder. Title: Re: Brake light switch Post by: merv on October 31, 2021, 01:52:33 PM Thanks Dave Title: Re: Brake light switch Post by: TwistedPatience on November 20, 2021, 01:22:22 PM Hydraulic switches are by far the best mines been on for the whole life of the trike and never had a problem.
Title: Re: Brake light switch Post by: merv on November 24, 2021, 02:51:23 PM Thanks Twisted
