Title: MX5? Post by: Manky Monkey on December 30, 2017, 02:57:29 PM One of my customers had this parked on his drive this morning. I know he's into kit cars but he wasn't around to ask.
Is it a naked MX5? Definitely a Mazda engine. Interesting single spine chassis design with the propshaft running inside the 3 sided channel that formed the spine. Title: Re: MX5? Post by: Manky Monkey on December 30, 2017, 02:58:00 PM .
Title: Re: MX5? Post by: merv on December 30, 2017, 05:44:48 PM That looks interesting
Title: Re: MX5? Post by: phunkie hiboy on December 30, 2017, 05:48:09 PM Yes, MX5.
Title: Re: MX5? Post by: Manky Monkey on December 30, 2017, 10:26:41 PM So not monocoque then?
I'll try & find out what he plans to build from it. Title: Re: MX5? Post by: phunkie hiboy on December 30, 2017, 11:25:34 PM Yes, monocoque. Just 'cos it has a spine, does not mean it's like an elan. If you look at your pictures you will see that there are two subframes, one front and back( bit like a mini or 1100 really). They introduced the Mk1 in '89, don't think there was anybody making chassised sports cars apart from Morgan then.
Title: Re: MX5? Post by: Manky Monkey on December 31, 2017, 09:14:32 AM I'm curious to see what he does with it now :)
Title: Re: MX5? Post by: Olds on December 31, 2017, 11:08:37 AM The girder like section is called the power plant frame and is bolted to the gearbox and the differential.
Title: Re: MX5? Post by: Manky Monkey on December 31, 2017, 12:15:44 PM Aah, of course -because it's IRS. I was trying to figure out how the axle moved, but of course, the diff' doesn't.
So does the bodyshell lift off in one piece then? Title: Re: MX5? Post by: kapri on December 31, 2017, 12:33:28 PM If anyone needs one I have an MX5 early 1600 with auto and prop /cat/ wiring etc pls logbook and all vin tags to use for BIVA.
Title: Re: MX5? Post by: Manky Monkey on December 31, 2017, 02:53:56 PM :)
Title: Re: MX5? Post by: Olds on December 31, 2017, 03:51:30 PM Aah, of course -because it's IRS. I was trying to figure out how the axle moved, but of course, the diff' doesn't. So does the bodyshell lift off in one piece then? Yep but the springs/shocks mount to the body in a similar way to MacPherson struts. Does make the power plant and drive train very suitable for mounting on a simple ladder chassis. Body rust is the big problem with MX5's but there are a lot of kits out there. From Ferrari lookalikes to Ariel Atom like type cars. Title: Re: MX5? Post by: Manky Monkey on December 31, 2017, 04:37:51 PM The guy I bought my replacement Rover V8 from had rebuilt it to put into an Atom style kit, then changed his mind & went for an MX5 motor instead.
Title: Re: MX5? Post by: poprodder on December 31, 2017, 05:04:08 PM rebodied mx5
(https://www.mx5parts.co.uk/info/wp-content/uploads/2016/03/SWB5_635.jpg) Title: Re: MX5? Post by: merv on December 31, 2017, 07:02:36 PM Thats nice
