Title: A life of vice. Post by: Olds on November 28, 2017, 10:01:21 PM Recently managed to break the front jaw clean off of my big bench vice. :'(
Bought an even bigger, heavy duty one. When I say heavy i mean 60 Lbs heavy. :) Only problem is I'm going to have lower the bench or make a step to stand on to use it. ;D I will attempt to weld up the old one but, as it's cast iron, I'm under no illusion that it will be anywhere near as strong as before. Title: Re: A life of vice. Post by: Manky Monkey on November 29, 2017, 07:15:44 AM Ooh, shiny new! I love new tools :)
Title: Re: A life of vice. Post by: the coppersmith on November 29, 2017, 09:34:02 AM do you have cast rods? or dissimilar rods? big V grind and blast them in, it'll be fine, until next time :D dont forget pre heat and post heat on cast. You'll be fine, what can possibly go wrong (my Mantra)
Title: Re: A life of vice. Post by: Olds on November 29, 2017, 10:05:09 AM NiFe rods. These worked for a welding a 3/4" Hardox steel surface to my cast iron anvil. I might strap the sides to add a little more strength. One handy thing about having a forge is being able to get large lumps of metal very hot.
Title: Re: A life of vice. Post by: Olds on November 29, 2017, 11:32:50 AM Not the prettiest of welding but should hold it together, for a while at least. Deep V prepped (3/4 depth) root welded then filled.
Title: Re: A life of vice. Post by: paulywombats on November 29, 2017, 12:53:00 PM Not even a good boat anchor
Title: Re: A life of vice. Post by: stinkey on November 29, 2017, 11:35:00 PM Definitely not pretty but hey ,who gives a :D if it works..cool
Title: Re: A life of vice. Post by: Olds on November 30, 2017, 05:22:19 AM Well as a vice it works fine, but I wont try to press any bearing with it. ;)
Had difficulties (read never found) the right setting for the rods. It was always either too low an amperage to sustain a good arc or turn it up till it would arc nicely and the rod would quickly overheat over it's entire length. :-\ Title: Re: A life of vice. Post by: spanners on November 30, 2017, 02:42:36 PM Recently managed to break the front jaw clean off of my big bench vice. :'( Where did you buy the new one from and if you don't mind how much was it ?? As when I went back to collect my stuff some body had nicked my vice Bought an even bigger, heavy duty one. When I say heavy i mean 60 Lbs heavy. :) Only problem is I'm going to have lower the bench or make a step to stand on to use it. ;D I will attempt to weld up the old one but, as it's cast iron, I'm under no illusion that it will be anywhere near as strong as before. Title: Re: A life of vice. Post by: Olds on November 30, 2017, 05:07:59 PM I bought it from Sitebox. £80.59 inc. delivery.
