Title: Filler primer or primer filler Post by: the coppersmith on March 15, 2017, 01:47:10 PM As the title says, bare steel, primer or filler first ?
Title: Re: Filler primer or primer filler Post by: Sid_Vicious on March 15, 2017, 02:55:47 PM when I learned to spray paint for offshore use we always primed first before anything else....
Title: Re: Filler primer or primer filler Post by: minimutly on March 15, 2017, 04:49:20 PM Ah but did you use body filler? I wouldn't put filler on paint, of any sort, but that's just the view of a self taught bodger...
Title: Re: Filler primer or primer filler Post by: stinkey on March 15, 2017, 06:34:21 PM Primer first then filler but these days doesn't make much difference ? ;)
Title: Re: Filler primer or primer filler Post by: Manky Monkey on March 15, 2017, 07:52:36 PM I've done a bit of both on my truck, with the appropriate amount of surface keying first, but it's quite a fine body filler.
Title: Re: Filler primer or primer filler Post by: phunkie hiboy on March 15, 2017, 07:52:49 PM Epoxy primer to seal the metal. Ordinary primers 1k or 2k let water in. You can fill over epoxy, sand it back a bit then fill.
