Title: dimple die Post by: triker_Chewie on December 09, 2014, 08:45:13 AM wazzled this up at work last night
20mm hole 45deg dimple out to 32mm. pressed on a hydraulic press (http://i49.photobucket.com/albums/f291/chewie66666/20mmdimple_zpsa70ae520.jpg) after this shot i parted the female oiece and i'm on the hunt for a long enough bolt Title: Re: dimple die Post by: Olds on December 09, 2014, 07:07:13 PM Nice :) Planning on making some bomber seats ?
Need to make one like that for 52mm holes. Title: Re: dimple die Post by: triker_Chewie on December 09, 2014, 07:17:29 PM a friend was looking at the cost of a set. so easy to make i wouldnt buy them. i should be able to blag the stock from work.
looking for some 3 inch bar for the big stuff Title: Re: dimple die Post by: Manky Monkey on December 09, 2014, 09:58:18 PM Always love the look of those holes.
Title: Re: dimple die Post by: morrag on December 09, 2014, 11:06:15 PM Mr.M how can you like a hole?! ;D.it's a blo.....y hole, nufink, zilch, in fact...a hole! :P :P :P :P :P :P :P :P
Title: Re: dimple die Post by: the coppersmith on December 10, 2014, 09:52:03 AM So, in the dark, does it become a black hole ???
Title: Re: dimple die Post by: twisted on December 10, 2014, 10:12:07 AM and what if you sit down on it ???
Title: Re: dimple die Post by: triker_Chewie on December 10, 2014, 01:53:32 PM it becomes uranus
Title: Re: dimple die Post by: Baychimp on December 10, 2014, 10:56:17 PM If you talk about it enough it becomes a bore hole. ::)
Title: Re: dimple die Post by: markju on December 10, 2014, 11:15:27 PM Spent what seemed like monthes of my life as an apprentice using a fly press to make holes like that. Simple tooling and every time it punched through I had to wrestle the steel sheet off it. And me only weighing about eight stone at the time with the upper body strength of a three year old! :)
Title: Re: dimple die Post by: trev on December 11, 2014, 01:50:00 PM I like looking in holes,but not as much as hiding behind trees,does anyone else,or have I finally gone completely bonkers. :(
Title: Re: dimple die Post by: morrag on December 11, 2014, 02:49:52 PM The hole part aint so bad Trev, you could perhaps form a club with Andy! ;D..but not sure about the tree hiding, look what happened to Red Riding Hood, can't be too careful, so best give that part a misss, unless your related to David Attenborough mebee......................
Title: Re: dimple die Post by: BikerGran on December 11, 2014, 08:21:12 PM I like looking in holes,but not as much as hiding behind trees,does anyone else,or have I finally gone completely bonkers. :( I used to hide behind trees a lot when I had a dog, but have no reason to do so since the dog died. RIP dog! Title: Re: dimple die Post by: andyrennison on December 26, 2014, 12:30:42 AM Dogs dig holes
Title: Re: dimple die Post by: triker_Chewie on December 26, 2014, 05:29:58 AM you funny guys.............
now made a 32mm. looks the same but bigger. got nicer cuts this time |
