Title: Piggy Engine Post by: Plasticpig on June 09, 2014, 12:34:10 PM Hi All.
Could I ask if someone could measure from the center of the crank shaft/timing pully, to the top of the tappit cover for me? Thanks.Doug Title: Re: Piggy Engine Post by: Olds on June 09, 2014, 02:05:39 PM 295mm to the flat top, plus 40mm filler tube, then the breather and pipe adds another 40mm or so.
This was measured in situ, so measurements are approximate. Title: Re: Piggy Engine Post by: Plasticpig on June 09, 2014, 03:53:55 PM Thank you, Olds.
Just what I wanted. Cheers.Doug |
