Title: SWEDISH STYLE TRIKE Post by: terry t on December 27, 2013, 06:47:55 PM Hi has any one got ant info on how to build a Swedish style trike/VW mid engine trike, plans or a project some one selling ::)
thanks Title: Re: SWEDISH STYLE TRIKE Post by: Manky Monkey on December 27, 2013, 09:32:16 PM There used to be a site called Swedish Trike Garage Terry, but I can't seem to find it. Type that into Google though & it comes up with photos of a few examples of the breed.
Title: Re: SWEDISH STYLE TRIKE Post by: terry t on December 27, 2013, 10:06:29 PM There used to be a site called Swedish Trike Garage Terry, but I can't seem to find it. Type that into Google though & it comes up with photos of a few examples of the breed. I've done that Andy, got some info on engine and gearbox layout, but cant find any thing on the frame set up Title: Re: SWEDISH STYLE TRIKE Post by: hunter on December 27, 2013, 11:21:37 PM I'm sure there are photo's on the old section of the site.
Title: Re: SWEDISH STYLE TRIKE Post by: triker_Chewie on December 28, 2013, 12:56:27 AM I started planning one of those. I'll email you a mountain of photos if you like.
Title: Re: SWEDISH STYLE TRIKE Post by: Olds on December 28, 2013, 09:13:25 AM You planning on mid engine or front engine ( spaced out transmission ) Terry?
Title: Re: SWEDISH STYLE TRIKE Post by: terry t on December 28, 2013, 11:00:22 AM I started planning one of those. I'll email you a mountain of photos if you like. yes please if you look in the member list under my user name there's my email. if there's a problem pm me thanksTitle: Re: SWEDISH STYLE TRIKE Post by: terry t on December 28, 2013, 11:05:25 AM You planning on mid engine or front engine ( spaced out transmission ) Terry? Hi Dave a front engine some thing like this set up 8)looking for more detail on frame build (http://i43.tinypic.com/2gvspox.jpg) Title: Re: SWEDISH STYLE TRIKE Post by: Olds on December 28, 2013, 11:38:55 AM Like building most car engined trikes it's probably best to get the engine/transmission and forks sorted then design the frame to suit those and to get the look that you are after.
There are drawings to suit VW rear engine trikes on the net but I have not seen any for front mounted. Title: Re: SWEDISH STYLE TRIKE Post by: terry t on December 28, 2013, 11:44:12 AM Like building most car engined trikes it's probably best to get the engine/transmission and forks sorted then design the frame to suit those and to get the look that you are after. There are drawings to suit VW rear engine trikes on the net but I have not seen any for front mounted. I know mate don't like rear engine, there was some one out there that made these frames ??? its this or a v6/8 on the same lines small and compacted 8) Title: Re: SWEDISH STYLE TRIKE Post by: triker_Chewie on December 28, 2013, 01:06:10 PM ther is a mob in the states that claim to build these
http://badasstrikecompany.webs.com/ Title: Re: SWEDISH STYLE TRIKE Post by: kapri on January 04, 2014, 06:39:47 PM Two of my mates built front engined VW trikes waaaaay back. One was back in around '75 or so ,Terry Howell ( Hoot) who also worke dfor Cutom City ( Jagos bike side ).
Pete Wells ( bike was called Electric Blue ) later built another but without the long forks , put on the road back in 79/80 . He used to live down in Havant not far from the Wheelwrights but I haven't seen him in years. From memory you have to turn the crown wheel and pinion around ( just a spanner procedure ) , it's used the same way in Split buses with wheel transfer boxes .Both ended up with reversed gear pattern, think sitting in the front seat but facing the rear window for shift pattern. Anyway, main point was they just laid them on the floor and built frame to suit . Rear ends were very basic. Title: Re: SWEDISH STYLE TRIKE Post by: Plasticpig on January 04, 2014, 08:19:48 PM Terry.
I bought a vw gearbox with swing axle last summer, and have been thinking about some sort of vw/Reliant hybrid. Either rear engined or Mankey style front. Title: Re: SWEDISH STYLE TRIKE Post by: the coppersmith on January 05, 2014, 10:43:34 AM I have seen a few grass track and whatever with the mid engine to VW gearbox, I seem to remember if you used early van box you did away with the reduction gears on the end, but someone just turned the box over on a newer one, the linkage was now at the back and the drain plug at the top, easily sorted I would have thought, they were running a V8 rover in the middle of a beach buggy
Title: Re: SWEDISH STYLE TRIKE Post by: BikerGran on January 05, 2014, 04:14:29 PM Never fancied a rear engined trike - not only are they usually short of luggage space but they wheelie to easily!
Title: Re: SWEDISH STYLE TRIKE Post by: morrag on January 06, 2014, 08:16:57 PM Found a couple of related VW trike pics. that came from the MM site orig. Morrag
Title: Re: SWEDISH STYLE TRIKE Post by: Olds on January 06, 2014, 09:02:34 PM Quite like the mid engine layout. Means you can mount the foot pegs lower and no empty transmission case as a spacer. Also better weight distribution than rear engine.
Title: Re: SWEDISH STYLE TRIKE Post by: morrag on January 06, 2014, 09:31:10 PM It's what the old time "Motorcycle" and "Motorcycling" mags. would have called a "coby" look!! from memory! ;D ;D ;D ;D ;D ;D ;D.....Morrag
Title: Re: SWEDISH STYLE TRIKE Post by: minimutly on January 12, 2014, 11:51:28 PM Warm bum as well!
You'need to be very tall or have long arms to ride that, but I agree, mid engine makes more sense than hanging out the back. Huw |
