Technical Section => Trike Tech => Topic started by: andyrennison on October 25, 2013, 11:00:47 AM
Title: Towing on a dolly
Post by: andyrennison on October 25, 2013, 11:00:47 AM
Hi All. I have been musing the issue of towing my trike. I have seen various ideas for dollies etc, and I'm ok with that aspect now. What I am wondering is about the electrics and lighting when on tow. Is it legal to hook into the existing electrics on the Trike, so the trike rear lights are in use?
If so, would I need to fit triangular reflectors and the towing vehicle plate while towing ?
Title: Re: Towing on a dolly
Post by: Olds on October 25, 2013, 11:15:27 AM
Should be OK but I think you may just be adding complications to the trike wiring.
Post by: steven brock on October 25, 2013, 12:28:01 PM
Hope those 40 horses can cope .. Lol
Post by: andyrennison on October 25, 2013, 03:47:53 PM
Yes, maybe, I suppose the other option is a towing board
Post by: andyrennison on October 25, 2013, 03:48:29 PM
This is to tow the trike behind my car Steve, not use the trike to tow :)
Post by: steven brock on October 25, 2013, 07:10:08 PM
Ah gotcha :)
Post by: scannerzer on October 25, 2013, 08:43:01 PM
if you are putting a towbar on then the same socket would serve bot purpose's
Post by: BikerGran on October 25, 2013, 11:05:06 PM
Think you would need the reflectors etc, depending on overall length.  You need brake lights as well and I don't see how you'd use the trike lighting for that.  Why not just use a board, makes life much simpler?  Also makes it quite clear to traffic behind that you're towing.
