Technical Section => Trike Tech => Topic started by: gpz on July 15, 2013, 05:34:00 PM
Title: hubs
Post by: gpz on July 15, 2013, 05:34:00 PM
before i put the hubs back on to my relaint axle should i put some copper slip on the taper to make them easier to split if i need them of again
Title: Re: hubs
Post by: morrag on July 15, 2013, 07:17:47 PM
In short, no, the tapers should be clean and dry on assembly, or you might find yourself relying on a very small Woodruff key alone for your drive!! Morrag
Title: Re: hubs
Post by: gpz on July 15, 2013, 07:19:56 PM
thanks morrag i knew someone would have the answer
Title: Re: hubs
Post by: spanners on July 15, 2013, 09:48:01 PM
same set up on a jag /salisbury 4ha axle also fitted to reliant scimitars and they recomend a light coat of anti sieze compound or ,rouge, (there wording not mine )
Title: Re: hubs
Post by: morrag on July 15, 2013, 10:16:10 PM
Well,"yer pays yer money........" but that's the way I have fitted tapers all my life, and I'm an old geezer now!!, anyway................................Morrag
Title: Re: hubs
Post by: andyrennison on July 15, 2013, 10:27:49 PM
Well, my hubs were a real bugger to get off, no sign of oil or grease. Don't expect to ever take them off again and the secure ness was reassuring. I'd rather struggle in 10 years than have problems in the next 6 months, so mine went on as I found em, dry!
