Title: Exhausted (nearly) Post by: andyrennison on July 10, 2013, 09:50:14 PM Ive don e some work on the exhaust routing today. All has gone well, i do however face one little issue. I am running the front pipe above the frame centrally near the prop shaft. That works well but it crosses and recrosses the frame above the frame. I would like to support it at those points but not transfer the heat onto the frame. Any suggestions?
Title: Re: Exhausted (nearly) Post by: andyrennison on July 10, 2013, 09:50:40 PM .
Title: Re: Exhausted (nearly) Post by: andyrennison on July 10, 2013, 09:55:12 PM ..
Title: Re: Exhausted (nearly) Post by: spanners on July 10, 2013, 10:02:47 PM tab brackets n, mini exhaust ,bobbins, ;)
Title: Re: Exhausted (nearly) Post by: andyrennison on July 10, 2013, 10:08:10 PM like these Mike?
http://www.ebay.co.uk/itm/CLASSIC-MINI-REAR-EXHAUST-MOUNTING-PACK-of-4-COTTON-REEL-BOBBIN-TYPE-/121134402639?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c342c4c4f Title: Re: Exhausted (nearly) Post by: Manky Monkey on July 10, 2013, 10:11:27 PM That's them Andy.
I used them on my truck but the rear ones have started to split. Mr Kapri told me they shouldn't be used to suspend an exhaust from as I've done, but should sit under the pipe so it's weight is on them, rather than hanging off them. The mounting studs are usually Imperial by the way, not Metric, (had a mate try to force a Metric nut on one a while ago). Title: Re: Exhausted (nearly) Post by: spanners on July 10, 2013, 10:20:23 PM like these Mike? thats them when in there original position on a classic mini they were/are mounted with the studs horizontal and used to last quite well but they last almost for ever when mounted in commpression ,http://www.ebay.co.uk/itm/CLASSIC-MINI-REAR-EXHAUST-MOUNTING-PACK-of-4-COTTON-REEL-BOBBIN-TYPE-/121134402639?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c342c4c4f Title: Re: Exhausted (nearly) Post by: andyrennison on July 10, 2013, 10:22:51 PM Ordered, coming on Friday. Its starting to feel like it will be finished sooner rather than later :) I have great plans for the leather trim :)
Title: Re: Exhausted (nearly) Post by: Manky Monkey on July 11, 2013, 06:18:11 PM Ooh, sounds interesting!
Title: Re: Exhausted (nearly) Post by: scannerzer on July 11, 2013, 07:14:52 PM I have just bolted mine solidly to the frame ,as the engine is ridgedly mounted it shouldn't need to move.
or is your engine rubber mounted,maybe i'm jumping the gun Title: Re: Exhausted (nearly) Post by: spanners on July 11, 2013, 07:54:55 PM I have just bolted mine solidly to the frame ,as the engine is ridgedly mounted it shouldn't need to move. youde be suprised how much an exhaust moves as i expands or is your engine rubber mounted,maybe i'm jumping the gun Title: Re: Exhausted (nearly) Post by: Manky Monkey on July 11, 2013, 08:00:43 PM I've rigid mounted exhausts in the past without any problems, but would still rubber mount them I think. Even though the motor's solid mounted, there are still vibrations & stresses transmitted to the pipes. I'd be concerned about stress fractures.
Title: Re: Exhausted (nearly) Post by: andyrennison on July 11, 2013, 10:44:18 PM I hadn't thought about the stress fractures part of it, but yes, vibration, oscillations and mostly heat. I want to keep the heat from transferring directly to the frame.
Title: Re: Exhausted (nearly) Post by: andyrennison on July 11, 2013, 10:45:54 PM Ooh, sounds interesting! I hope so, we are going to make some nice curved tunnel panels with all that leather, and finish the front edge to the frame with stainless mesh. May mock one up this weekend to get the look of it. |
