Technical Section => Trike Tech => Topic started by: andyrennison on July 05, 2013, 07:46:04 PM
Title: Brake line fixing
Post by: andyrennison on July 05, 2013, 07:46:04 PM
I am proposing to use this method for fixing the brake pipes and handbrake cable. A hole is drilled and tapped, then the pipe is secured using a stainless p-clip with rubber liner and a stainless screw. Is this acceptable for the msva?
Title: Re: Brake line fixing
Post by: andyrennison on July 05, 2013, 07:47:08 PM
Post by: Manky Monkey on July 05, 2013, 08:13:13 PM
Should be, provided the pipe can't move in the clip & the mounting hole doesn't seriously weaken the frame tube, (should be fine on thick walled ERW tube, but maybe keep away from high stress areas if you can).
Post by: WAYNE999 on July 05, 2013, 08:40:14 PM
More than fine mate,my hand brake cables are held up with cable ties and the brake pipes with "double loop" cable ties so p-clips fitted properly will be fine
Post by: andyrennison on July 05, 2013, 08:48:44 PM
3mm CDs so that's ok then. Point taken about stress points :)
Post by: andyrennison on July 05, 2013, 08:50:52 PM
Thanks Wayne. That is very reassuring. The copper will be nickel plated (replica chrome) so I want the fixings to set that off :) was worried what was needed.
Post by: scannerzer on July 05, 2013, 08:51:47 PM
I've did the same thing Andy so hopefully should be ok and looks neat
Post by: andyrennison on July 05, 2013, 08:55:39 PM
Thanks  Scannerzer. Yes, I saw some P clips on your build (I think )
Post by: Olds on July 06, 2013, 06:57:12 AM
For the brake pipes, because I didn't want the hassle of drilling, I used zip ties with short (5mm) lengths of 6mm plastic tube to form the stand offs.
MSVA inspector was more than happy about this.
Post by: Manky Monkey on July 06, 2013, 08:58:35 PM
That's equally tidy Dave -& ingenious.
Post by: WAYNE999 on July 07, 2013, 08:10:14 AM
These are what I used and the VOSA man was happy
http://www.cabletiesonline.co.uk/cable-ties-other/double-loop-style-cable-ties-200-x-4-8mm/prod_1118.html
