Technical Section => General Tech => Topic started by: Clive on April 28, 2013, 08:06:48 PM
Title: Carbon removal
Post by: Clive on April 28, 2013, 08:06:48 PM
Anyone got any top tips for removing excessive carbon build up in engine parts?
Title: Re: Carbon removal
Post by: spanners on April 28, 2013, 08:23:00 PM
blunt scraper ,, or sometimes good old  ,coke a, cola works  ;)
Post by: Clive on April 28, 2013, 08:35:32 PM
Cheers buddy, can't get a scraper in there, it's a heat riser on a VW engine!
Post by: hunter on April 28, 2013, 08:57:42 PM
If it's steel soak it in caustic.
Always good to remove carbon.
Post by: Clive on April 28, 2013, 09:26:53 PM
It's had four lots of caustic soda mix in it so far!!!!!!
Post by: hunter on April 28, 2013, 09:28:52 PM
But for how long,It does take time.
Post by: Clive on April 29, 2013, 06:05:15 AM
Overnight each time!
Post by: Olds on April 29, 2013, 06:39:04 AM
If the carbon is very oily the caustic doesn't always work well. On two stroke exhausts we used to burn the oil off first with a blow torch.
Post by: hunter on April 29, 2013, 07:55:21 AM
Yep that's exactly what we used to do in the day.
But it you send your two stroke ex to a plating company they will soak it in hot caustic for day's,
Maybe a week,They must be clean before they will put them in the tanks.
