Title: top end engine noise + vid Post by: poprodder on April 03, 2013, 04:03:52 PM hi,
had my 2.8 cologne running and from the start theres been a terrible noise from top area, oil and filter changed, not water pump or alternator, seems to be a very mechanical grinding sound from top end, not a tapping or banging noise. will try to get a video up of noise, but anyone got any ideas? beggining to think i need to look for another engine as this was bought very cheaply unknown condition. (not an open cheque build either!!!) any pointers or help please. cheers chris. Title: Re: top end engine noise + vid Post by: poprodder on April 03, 2013, 07:41:43 PM been told it could of spun cam bearings.
http://www.youtube.com/watch?v=UOb8YaZVj3U&feature=youtu.be Title: Re: top end engine noise + vid Post by: Manky Monkey on April 03, 2013, 07:54:59 PM Didn't Mr CunningPlan have a spun bearing on his race motor recently?
Title: Re: top end engine noise + vid Post by: spanners on April 03, 2013, 08:17:57 PM sounds more like timing gears,,
has it got oil pressure, ? Title: Re: top end engine noise + vid Post by: poprodder on April 03, 2013, 08:26:17 PM well the light goes out quickly, someone has pointed out that the noise doe'snt speed up when i rev it.
Title: Re: top end engine noise + vid Post by: hunter on April 03, 2013, 08:56:20 PM Get the rocker covers off,It sounds like it's in the valve train.
Title: Re: top end engine noise + vid Post by: poprodder on April 04, 2013, 06:44:45 PM removed rocker cover this evening, started her up, oh s**t, no oil.
Title: Re: top end engine noise + vid Post by: hunter on April 04, 2013, 07:19:23 PM Blocked oilway How much damage.
Title: Re: top end engine noise + vid Post by: toad on April 04, 2013, 08:13:29 PM Cologne v6's had plastic drive gears (kid you not google it) Sounds like the pump gear has stripped hence next to no oil pressure just enough to put the light out and not a lot more. :o :o :o
Title: Re: top end engine noise + vid Post by: poprodder on April 04, 2013, 09:46:49 PM cheers, its not looking good. >:(
