Technical Section => General Tech => Topic started by: ROD on January 07, 2013, 04:53:46 PM
Title: Grade of aly for a hub?
Post by: ROD on January 07, 2013, 04:53:46 PM
Does anyone have any knowledge of types of aly,and what grade I would need for a rear hub? Im going to machine this myself to cut down on costs.
 The hub will have the sprocket,disc and wheel mounted on it with a bearing on each side to fit a shaft of approx 25mm. Im roughly guessing the hub will be approx 10 inches wide. Thanks
Title: Re: Grade of aly for a hub?
Post by: phunkie hiboy on January 07, 2013, 06:56:31 PM
HE30 or T6, same grade different designation.
Post by: Olds on January 07, 2013, 07:35:31 PM
As ph says 6082-T6 or perhaps T651.
At 10" wide thats going to be quite a big bit of ally. Have you thought about a built up hub using steel tube and flanges?
Post by: ROD on January 07, 2013, 08:23:25 PM
No I havent. Just thought that I would 'carve' it out of a chunk! Need to go investigate this more me thinks! Never really looked at a bike hub,so just designed it the way I thought.
Post by: hunter on January 07, 2013, 11:55:09 PM
Rod unless you know someone who can get you a piece on the knock or discounted,
It will cost you a mint :o
Have you thought about a single sided swingarm off a honda,They are cheap to by.
(http://i290.photobucket.com/albums/ll259/spares_photos/DSC_0977.jpg)
(http://i290.photobucket.com/albums/ll259/spares_photos/DSC_0979.jpg)
Post by: Olds on January 08, 2013, 08:06:33 AM
That is probably a good thing. Bike hubs are not designed to take the sort of lateral loading that the rear wheel in a reverse trike will produce
Post by: ROD on January 08, 2013, 02:38:36 PM
The swing arm can only be supported either side of the diff,so need a seperate 'connection' each side. Bike swing arms are too narrow IMHO. Ive got the design of the arm ok,but need to sort out the hub.
  Very basically.........I need a tube with a bearing in each end. Onto this tube will be mounted 3 discs. One disc positioned at one end of the tube for the wheel to mount to,one for the brake disc at the other end and one for the sprocket,just inside the brake disc one. I thought making this from one piece of aly would be the easiest .
   Should I make it from one piece of steel? or..the 'tube' and 3 seperate 'discs' welded to the tube,then trued up on the lathe?
 Unless I can get the correct diam tube in a decent grade of steel,the problem (for me)will be machining the tube from a piece of bar,cos it will need a very long boring bar.
  Getting deeper into this...the disc that holds the sprocket will have to be larger diam than the brake disc mount. The sprocket will have a large diam hole in it to be able to get past the brake disc mount.
Post by: Olds on January 08, 2013, 04:09:33 PM
I can see what you are trying to achieve, I assume you are trying to fit a car type wheel but would not be easier to have one flange to mount the wheel on, and one to mount the sprocket and disk to. The sprocket being sandwiched between the flange and the disc. that way you get the wheel- sprocket-disc in the order required with only two flanges, only the two outside faces that require truing and no problems getting the sprocket over the disc flange.
(You could also explore the possibility of welding two car rwd type front hubs together. Just a silly thought but maybe..)
Post by: ROD on January 08, 2013, 04:38:55 PM
That might work.I see where youre coming from!
  I thought of the welded hubs idea,but wouldnt work without lots of machining,so I reckon simpler to make all new.I have a hub (spitfire) that fits the wheel,so maybe able to fit and weld this on one end of the tube for the wheel mount.
 The sprocket will have to be spaced away from the brake rotor to get the caliper in there.
 Hmmmm..thinking about this ON .IF I could get the hubs back to back together and on a tube,it would save me a mountain of work (and money for the billet) wouldnt it?
Post by: nabsim on January 08, 2013, 07:08:29 PM
Is that a typo Rod? You haven't got a diff if its only one wheel have you?
Post by: Olds on January 08, 2013, 07:26:26 PM
I think he's locked it and using it as a bevel box to allow for chain drive.
Rod I'm sure you've thought of this- mounting the sprocket to the 'outside' of the wheel and use a standard front hub .
Post by: ROD on January 08, 2013, 07:51:49 PM
Yes,got diff Nabs,but as ON says,will be welded locked,and chain drive off one flange(Spits are independent rear ends)
Post by: scannerzer on January 08, 2013, 10:49:01 PM
a rear hub of a mk4 astra or mk5 golf might let you away
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA-G-MK4-1998-ON-REAR-WHEEL-BEARING-4-STUD-/300216513855?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45e64c753f (http://www.ebay.co.uk/itm/VAUXHALL-ASTRA-G-MK4-1998-ON-REAR-WHEEL-BEARING-4-STUD-/300216513855?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45e64c753f)
golf is similar idea
Post by: TwistedPatience on January 09, 2013, 12:07:00 PM
T6 definatly.
Post by: nabsim on January 09, 2013, 01:59:41 PM
Anaheim, it becomes clear :)
Grrrrrrr, soddin auto text correct rubbish. That should have said Ahah :)
Post by: ROD on January 09, 2013, 08:00:23 PM
You bin sniffin summat Nabs? ;D
 After looking at a couple of hubs,I think Im going to go for a steel tube with a bearing in each end as a basis for the hub.As Morrag suggested a halfshaft from a car will be the correct grade of steel to make the axle of. I have a A40 half shaft which is 1" od,so that means the outside diameter of a 1" id  bearing will control the size of the tube I use. Ive looked at the Spit hub I have,and it may be ok to machine out the centre to fit over the o.d. of the tube,which Im guessing will need to be about 60mm od. . This will be the wheel mounting. I havent sussed out what to use for the sprocket /disc mount at the other end of the tube.
 So-o-o..this brings me to my next question. The tube..Should I use a solid piece of steel and get it bored out to suit,or should I try to get hold of a lump of thickwalled tube ? My thoughts are that a piece of tube will be hard to find in the size I need.
Post by: morrag on January 09, 2013, 08:07:20 PM
Rod, Personally I'd prefab. it from M/S tube and plate, making the sprocket double as a rear disc, for the power output your using you wont require any high spec material, just sufficient wall thickness around the bearing area. Set it up and finish the mating faces, good penetration welds, jobs a good 'un, Morrag
Post by: hunter on January 09, 2013, 10:48:05 PM
I did have some years ago two hubs,One Ali one steel.They were removed from a couple of sprint bikes.They were fitted with car wheels,I know i gave the Ali one to a mate,But i keep thinking i still have the steel one,Give me until the end of the week to look,i have to move some stuff to look,
But if i can find it, and it's of use to you it's yours for postage.Mind tis heavy,
I am not 100% sure i have it but i don't remember giving it away,
I remember
Post by: ROD on January 10, 2013, 07:06:26 PM
ok thanks.
  The idea I have come up with is to use 2 A40 hubs(like trailer hubs) back to back with a spacer in between,about 75mm long. I enquired at a welding forum if they thought the proposed mild steel tube would weld ok to the cast hubs. Ive welded stuff to hubs before,but never as structural. They reckon it wont be too succesfull. So Im now looking for some billet hubs(expensive) or using some other idea.
Post by: Manky Monkey on January 10, 2013, 08:20:27 PM
Is there some way of joining the hubs to the spacer tube that doesn't involve welding them? Can you bolt them through the wheel stud holes? Are the centre holes where the drive shaft normally fits keywayed? Could you make some sort of woodroffe keyed spacer tube? A large diameter sleeve that fits between the hubs with end plates that attach to the wheel studs? Dunno, but there must be a way of doing it.
Post by: ROD on January 10, 2013, 09:15:49 PM
Yes Andy,I have thought about bolting through the flanges etc. I think the best way is to do as Morrag suggested and make it completely from scratch. Basically a tube with a flange on each end,and a bearing in each end of the tube ,as I described in an earlier post.
 Ive done similar a few times for my karts,but this has to be a lot more accurate. I only have the use of a basic lathe,so it may be a problem getting the pcd holes concentric. I'll have to have a think....
Post by: hunter on January 11, 2013, 12:05:03 AM
What size plate are you going to use for the flanges,
Thickness and dia.And how many bolt holes to mount disk and sprocket.
Post by: ROD on January 11, 2013, 02:24:22 PM
I'm thinking 12mm or 15mm plate for the flanges. Wheel will be 4 bolts. Sprocket ,dont exactly know yet,as have to look at sprockets,but 6 maybe.Will have to make some sort of adapter for the 4 bolt fixing on a Nova disc........Sheesh! this is getting in far deeper than I wanted to go! I just cant apply my brain to all this at the mo' so Im gonna have a serious think about carrying on with this whole project. Thanks for the input guys,its been much appreciated..
Post by: Olds on January 11, 2013, 06:29:17 PM
Take a break for a while. Ideas as to how to proceed come a lot easier when not actually trying to build and designing on paper only wastes paper
Is there a reason that you are limiting yourself to a Nova disc? Trying to find a disc with the bolt pattern you want, might be easier.
Post by: morrag on January 11, 2013, 07:10:25 PM
Rod, Why not reconsider the drive line, and have another look at using a motorcycle shaft driven rear wheel, off a Honda, BMW, or similar. You could drop the very heavy Spit. diff, and, instead, shaft drive the rear wheel, with no chain involvement.
If you use a drum rear wheel that's also your handbrake sorted, and just brake the fronts off the foot pedal, as some other 3 Wheelers do, worth consideration don't you think? G'wan, g'wan.....g'wan, :D :D  Morrag
Post by: nabsim on January 11, 2013, 07:46:06 PM
You can get different ratios on the final drive for some BMWs I have them for sale now and then off sidecar outfits. Would be a lot of work sorted if you went for a para lever r similar as Morrag say Rod
Post by: ROD on January 11, 2013, 09:16:18 PM
Well,Im not trolling for sympathy one little bit ,but I really cant be doing with this project anymore,its just getting far more complicated  than what I intended,and I havent really got time to work it all out . I know its only a hobby,but sometimes during various stages of any build (and Ive been there very many times over the last 40 years)you need to put a lot of brainwork into it,and that wasnt what I intended at the outset of this project.My main stumbling block is knowing almost zero about m/cycles and what fits what and the various specs,models etc,let alone prices etc....(eg.....Nabs,I aint got a clue what a Paralever is!!)I thought I may start again,using a complete bike less the front end, stuffed up the rear of a chassis,at least the whole drive train would be in one unit then,but I havent got a clue how to even buy a bike and what to look for!  so Ive decided to sell it off .At least I'll get my garage space back then! I honestly do appreciate the efforts you guys have gone to with help with this rear hub etc.
Post by: nabsim on January 12, 2013, 10:30:15 AM
Sorry Rod, its just BMWs name for their single sided back end, think it is used for mono or twin shocks but definately mono shock. Para lever that is ;)
