Title: Inspect your nuts! Post by: RODeo on February 26, 2012, 08:29:35 AM Just my 2p..........
Ive used mostly nyloc nuts on the trike ,all new stainless steel. For some reason I used the correct imperial thread,but ordinary nuts ,not nyloc,(possibly cos they were out of stock when I ordered all my bolts)on the propshaft.I checked all the bolts for tightness after the first run out,but these are coming loose again ,even though they have the correct washer on them.Im putting this down to the vibration caused by the hadtail effect. Due to the prop being sort of buried under the seat and other stuff making it inaccesible(sp?),its an area which could be overlooked with dire consequences! So make sure all nuts are nyloc and arent able to loosen off. Title: Re: Inspect your nuts! Post by: mouse on February 26, 2012, 08:50:37 AM i use thread lock mate
http://www.ebay.co.uk/itm/230742472982?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 (http://www.ebay.co.uk/itm/230742472982?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649) Title: Re: Inspect your nuts! Post by: Manky Monkey on February 26, 2012, 10:15:39 AM I assume you're using a spring washer under the nut Rod? (made of sprung steel, it holds the nut in tension against the thread so it doesn't come loose). Nylocs work just as well, but obviously not in any situation where they're likely to get warm, (Nyloc- nylon insert in a normal nut. The bolt cuts a thread into the nylon as you tighten it, locking it against the bolt)
I haven't had a hardtail on the road for a couple of years now, but the regular Sunday morning maintenance check was part of the fun of riding & gave me something to tinker with after the initial build was finished. If you're really worried, you could go the old fashioned racing route & wire lock the nuts. Tighten them up, then use a small drill to drill right through the side of the nut, bolt & out the other side. Thread a length of wire through & twist the ends together. Check the race/kitcar suppliers, such as Merlin Motorsport & you'll see they sell reels of wire & special lock wire pliers for the job. On a purely cosmetic front, lock wires can give a very retro race look to vintage vehicles too. Title: Re: Inspect your nuts! Post by: RODeo on February 26, 2012, 11:40:02 AM Yeah thread lock is one way to go,but I have occasionaly had probs with that over the years.
Title: Re: Inspect your nuts! Post by: snafu on February 26, 2012, 12:15:32 PM this site covers all aspects of nuts, bolts, washers, well woth a look
http://www.boltscience.com/pages/info.htm? Title: Re: Inspect your nuts! Post by: RODeo on February 26, 2012, 01:12:19 PM Interesting info,will have aread of that later,thanks
Title: Re: Inspect your nuts! Post by: fifer on February 26, 2012, 01:45:15 PM I have inspected mine for hairline cracks ;D ;D ;D
. . Title: Re: Inspect your nuts! Post by: RODeo on February 26, 2012, 03:44:36 PM Must be the cold weather up there! ;D
Title: Re: Inspect your nuts! Post by: BikerGran on February 27, 2012, 12:00:58 AM Mine's a softail but I once got to a rally and found I had LOST one of the bolts from the flange that joins the two parts of the propshaft - and the others weren't very tight! Threadlock has dealt with the problem though I do still check now and then....
Title: Re: Inspect your nuts! Post by: spanners on February 27, 2012, 12:02:42 AM found two pairs of ,,nutcrackers ,,,,, :o :o :o today
Title: Re: Inspect your nuts! Post by: Bus Boy on February 28, 2012, 12:10:09 AM be carefull useing threadlock in areas where ya wouldn't use nylocs.....i.e. high temperature areas , cos the recomended way of undoing fasteners which have been threadlocked is to heat them up to break the bond! so be aware!
Title: Re: Inspect your nuts! Post by: Bus Boy on February 28, 2012, 12:28:31 AM this may be of interest...........all metal locking nuts
http://www.conceptfasteners.com.au/Products/ThreadLocking/Assets/Documents/Profile2-BX.pdf (http://www.conceptfasteners.com.au/Products/ThreadLocking/Assets/Documents/Profile2-BX.pdf) have used them quite a bit at work......good in hot areas where nylon lock washers would met and threadlock may give up. another advantage is that they aren't very tall so should be good for limited space areas such as prop uj's! Title: Re: Inspect your nuts! Post by: spanners on February 28, 2012, 12:30:17 AM bus-boy = nuts are we talkin 10 stud and -badk -to-slack ,, ;) ;)
