May 21, 2024, 08:50:34 PM *
Pages: 1 ... 11 12 [13] 14 15
Author Topic: look at what i have been given  (Read 52841 times)
« Reply #180 on: April 29, 2018, 11:03:22 AM »
According to Google you can lay on side, they should not be charged with the terminals facing downwards as gel may vent in this position.
Living on a wing and a weld
« Reply #181 on: April 29, 2018, 11:10:00 AM »
What do you want to lay it on its side for merv.
« Reply #182 on: April 29, 2018, 05:09:09 PM »
I'm thinking of moving it's position
« Reply #183 on: April 29, 2018, 05:42:53 PM »
Plenty of room to move it to on a trike
« Reply #184 on: May 19, 2018, 06:15:19 PM »
Not much to report at the moment new bars and clocks fitted. Clocks had to be completely rewired. Not happy with the bars i want them longer. I also think the clocks need lowering
« Last Edit: May 19, 2018, 06:17:00 PM by merv » Logged
« Reply #185 on: May 19, 2018, 06:19:11 PM »
New headlight and indicators fitted, the headlight has a halo side light just like bmw's
JayJay
« Reply #186 on: May 19, 2018, 09:11:18 PM »
... Not happy with the bars i want them longer. I also think the clocks need lowering
Do you mean wider or taller? I think that bars too wide on a trike makes it more difficult to turn. I think a bit taller would probably be more comfortable for you as you are tall.
« Reply #187 on: May 20, 2018, 05:33:09 AM »
Hi JJ
I do mean wider
« Reply #188 on: May 21, 2018, 07:46:04 PM »
Hey mate I've found some BARS for you? Roll Eyes
« Reply #189 on: May 22, 2018, 06:35:50 AM »
Remember that to comply with lighting regulations you need two front position lights (sidelights) on a trike that is wider than 1300mm.  Positioned max 400mm from the outside edge of the vehicle.
Looking good Merv.
« Reply #190 on: May 22, 2018, 04:15:14 PM »
Funny ha ha Steve.
From what you are saying about the side lights Dave, would it be acceptable to have one on either side of the rear mudguards.
« Reply #191 on: May 22, 2018, 10:05:51 PM »
Yep. Mine are mounted on the sides of the pickup body.  Less than 400 from the outside of the mudguard (widest point).
« Last Edit: May 22, 2018, 10:08:07 PM by Olds » Logged
« Reply #192 on: May 23, 2018, 08:55:05 PM »
My wider bars made mine much easier to turn and more comfortable too!  Though I did have extended yokes fitted at the same time, so can't be sure which bit helped most.
« Reply #193 on: August 05, 2018, 01:46:05 PM »
Just thought i keep you up to date with things, just changing the back of the frame slightly
« Reply #194 on: August 05, 2018, 01:59:07 PM »
from a different angle
