May 20, 2024, 02:56:00 PM *
Pages: 1 ... 147 148 [149] 150 151 ... 791
Author Topic: Manky's Pop.  (Read 1566792 times)
« Reply #2220 on: August 09, 2010, 08:59:49 PM »
Here you can see the flat straps that the guards sit on. Nice sticky out bits for Loony to catch his shins on when he opens up the workshop tomorrow.  Tongue
afghanman
« Reply #2221 on: August 10, 2010, 06:00:59 PM »
I quite like the rusty evolved look Cool
This is a van in a farmers yard just up the road from me, every time I pass the place I'm tempted to see if its for sale , ,,,,,,,,I don't think my wife would be too chuffed if I came home with it though Roll Eyes
http://i171.photobucket.com/albums/u284/afghanman_photos/IMGP0089.jpg
Manky's Pop.
pkdsculpture.moonfruit.com
« Reply #2222 on: August 10, 2010, 07:07:14 PM »
I reckon they look better than just a couple of bits of flat strap bolted on as an afterthought. If you have to have guards, they might as well be tidy ones.
That seems to be the theme running through everything you`ve ever built, and what makes them all stand out from the rest!
« Reply #2223 on: August 10, 2010, 07:54:47 PM »
Cool
That is looking the Bollox M8 Smiley love the shape on the mud guards and more important the shape of the bars holding them there Smiley
« Reply #2224 on: August 10, 2010, 09:18:05 PM »
Muppets.  Smiley
Some of the American rat rods have really gone overboard on the rust look, artificially oxidising panels & basically fitting the rustiest ol' tat they can find.
I like it when it's natural -the product of years of use & wear. The Yanks don't have to contend with our annual MOT test though. I don't want to shout "Look how tatty my car is" every time it goes for inspection or be praying I don't get pulled over every time a Police car appears.
Well used, well loved, maybe well driven, (!), but tidy &, hopefully, well engineered.
« Reply #2225 on: August 11, 2010, 04:51:57 PM »
the natural patina on my pop has been painted over by hand with a (what looks like) 2" brush!!! Shocked Sad
prefered for it to look well worn.
« Reply #2226 on: August 11, 2010, 09:33:52 PM »
to me (personal taste warning) rust = neglect
why spend a fortune in time and money only to have  a car/bike that looks like you dont care at all?
« Reply #2227 on: August 11, 2010, 09:40:16 PM »
Cos it's cool to appear ultra casual about such things -so I'm told. I'm more luke warm, than cool, so I'll stick to a nice coat of paint thank you.  Cool
« Reply #2228 on: August 16, 2010, 07:37:04 PM »
Swapped the faulty wiper motor for the reconditioned one I bought from Pop Browns today. It works fine, though we could do with a bit more sweep across the screen. By the time we've cut the blades down to suit the reduced screen height, they really won't do a lot, but we'll try to wipe as much of the screen as we can. There's a large drive cog inside the motor casing, which is replaceable. They're available in sweeps of 95 to 130 degrees. Mine's marked as 100, so I'll contact Kris at Pop Browns & see if he can get me a 130 one.
« Reply #2229 on: August 17, 2010, 09:55:20 PM »
Meanwhile, back to the front.
Having sorted out the first of the 2 front mudguard mounts, we found they sit very close to the headlights when on full lock. I also tried jumping up & down on the chassis & although the guards don't actually hit the headlights on full suspension travel, they get pretty close. We'd half expected that though & had a contingency plan. Move the lights.
They're on curved arms that I made ages ago, which are welded around the front corners of the chassis, helping to round off the pointy corners. By cutting them off & re-welding them onto the front face of the chassis, we moved them inboard by nearly an inch, giving us plenty of clearance.
I've taped over the glass light lenses to protect them from grinding sparks, which get embedded in the glass then go rusty.
I had to strip the front suspension & drop the radiator grille down to give us room to work on the chassis.
« Reply #2230 on: August 17, 2010, 10:00:21 PM »
Having cut the light mounts off, I trimmed them to fit flat on the front of the chassis, (a rare piccie of Manky at work -not that I don't work, just hate having my photo taken. Those are grey highlights, honest).
Safety first kids -always clamp the workpiece securely in a bench vice, wear protective gloves & only use power tools fitted with the correct safety guards. At least I'm wearing goggles.
« Last Edit: August 17, 2010, 10:03:11 PM by Manky Monkey » Logged
« Reply #2231 on: August 17, 2010, 10:06:15 PM »
Mr Lunatic then made good the angle-ground chassis corners & re-welded the light mounts.
« Last Edit: August 17, 2010, 10:13:24 PM by Manky Monkey » Logged
« Reply #2232 on: August 17, 2010, 10:11:55 PM »
The finished mounts. Same height, but about three quarters of an inch further inboard each side. While the front end was apart I took the opportunity to tidy up some of the other brackets & Loony fully welded some parts which were only tacked together.
« Reply #2233 on: August 18, 2010, 01:24:41 PM »
excellent progress,
what spring perches have you used? model y?
cheers chris.
« Reply #2234 on: August 18, 2010, 03:38:23 PM »
ignore above question, i've just read through and found answer.
