May 18, 2024, 09:18:25 AM *
Pages: 1 ... 207 208 [209] 210 211 ... 791
Author Topic: Manky's Pop.  (Read 1565215 times)
« Reply #3120 on: May 15, 2011, 10:48:24 PM »
that looks o.k from here  Wink
what did you do with the  redundent gauge,s  Cool Wink
may be able to re-home them  in the near future  Wink
« Reply #3121 on: May 16, 2011, 08:06:05 AM »
looking real good andy.
hotrod holes!!!!  love it!
« Reply #3122 on: May 16, 2011, 10:17:57 PM »
According to Loony, you can never have too many hotrod holes.
Sorry Mike, they were only a cheap set of autojumble gauges, (20 quid for a set of 3 from Pop Parts Plus). We'd threaded the sender units under the carb manifold, which involved having to completely unbolt it & lift it slightly. Couldn't be arsed to do it again, so I just chopped the ends off. So got the 2 gauges & the water temp sender bulb if you can reconnect it.
« Reply #3123 on: May 17, 2011, 11:59:06 AM »
There's nowt as light as a hole............  Wink
'cept maybe a hole filled with helium..............
« Reply #3124 on: May 17, 2011, 11:19:00 PM »
 Cheesy
I arrived at the workshop today to find Loony busy welding up the bulkhead components. I hadn't been 100% sure about it yesterday, but once it was all glued together it seemed to work. The demister air vent in front of the windscreen makes an interesting feature -obviously not standard fitment on a Pop, & helps to break up the flat expanse of bulkhead. Still got a little more to do, but it's looking promising.
« Reply #3125 on: May 17, 2011, 11:26:59 PM »
As most of the mechanical stuff's done now, I've become Loony's sheet metal apprentice. I cut & form the parts from whatever steel scraps we've got & Mr L weddles them together.
Once the bulkhead's sorted, we need to attach the bonnet. Like a lot of old Brit cars, Pop's have a 2 part bonnet with the 2 sides opening along a centre hinge strip. After remodelling the bulkhead, we needed a new place to fix the rear hinge mount. We tried a couple of ideas & through our usual process of mutual consideration, experimentation & compromise -standing & looking at it for a while, then trying a few ideas -I bent a short length of flat sheet & cut 2 triangular side pieces to make a small platform on the bulkhead. Just taped in place at the moment as it needs a couple of captive nuts inside it, but Loony will weld it in tomorrow.
« Last Edit: May 19, 2011, 08:42:34 PM by Manky Monkey » Logged
« Reply #3126 on: May 17, 2011, 11:29:03 PM »
The chrome hinge strip will need shortening to fit, but will sit about here.
« Reply #3127 on: May 17, 2011, 11:32:38 PM »
I also cut & shaped a few fill-in pieces for the rear of the cab. We've used Leyland Mini front wings, stood on end, to form the double curves of the cab corners, but they were shaped to fit against the bulkhead of the Mini, leaving a couple of triangular holes to fill in their new position. I've left them for Loony to weld in the morning.
« Reply #3128 on: May 18, 2011, 11:05:04 PM »
Bonnet hinge mount ...mount, tacked in place. With the hinge strip shortened to suit we could hang one side of the bonnet on to get some idea of how much we need to alter it. Because we've stretched the engine bay, we need to add an extra 2" or so into the bonnet length.
We've also finally straightened up the crooked grille, plus I've blanked off the unwanted gauge sender units on the engine, so we can run it again now.
« Last Edit: May 18, 2011, 11:11:40 PM by Manky Monkey » Logged
« Reply #3129 on: May 18, 2011, 11:07:01 PM »
It also has to be notched to fit around the air vent.
« Reply #3130 on: May 18, 2011, 11:09:36 PM »
Some time ago, I bought a second bonnet. We'll cut a 2" slice off one & graft it onto the other, though the second one seems to be in better condition than the original. Looks completely different with some bodywork on I think.
Cabman77
« Reply #3131 on: May 19, 2011, 08:11:32 AM »
it really does look the nuts Andy  Grin Grin Grin Grin
cunningplan
« Reply #3132 on: May 19, 2011, 09:27:47 AM »
Shame to cut up a good bonnet for just 2 inch's, looking at the work you have already done you should be able to bend up a couple of filler strips to make up the gap at the back. Get a 3 inch strip, fold back 1/2 inch. lay it on the back end and fold it around and trim off the front just behind the body line, weld in place, bit of filler and "presto" one extended bonnet. 2 Minuit job at the most   Roll Eyes
Looking good Andy
« Reply #3133 on: May 19, 2011, 10:44:59 AM »
nice work andy (&loony)
your getting there now.
« Reply #3134 on: May 19, 2011, 08:59:52 PM »
I think we're way past the point of worrying about butchering classic car parts Tony!
The back edge of the bonnet actually curves in several different directions -not that easy to replicate.
Anyway, it's too late cos I cut it up this afternoon! There's a raised lip along the back edge, which just happens to be exactly the width we need to lengthen the bonnet by. So I chopped it off the original panels, ready to splice back onto the better condition replacement ones.
