May 21, 2024, 11:57:44 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 48
Author Topic: Rennies Trike  (Read 195109 times)
trev
« Reply #210 on: September 19, 2012, 02:48:23 PM »
andy have you not got steering stops on your frame,they will stop it turning too far.
andyrennison
« Reply #211 on: September 19, 2012, 02:59:39 PM »
Hi Trev. Yes, I will be putting some rubber bump stops on to prevent it colliding. I was more worried that the angle of lock (about 45 degrees) would be enough.
one arm bandit
« Reply #212 on: September 19, 2012, 03:28:21 PM »
andyi think you can get rubber bump stops that slip over the fork stonsions there likea tear drop shape with said holein the middle Wink
andyrennison
« Reply #213 on: September 23, 2012, 08:06:30 AM »
Those sound ok. I'll check them out.
andyrennison
« Reply #214 on: September 23, 2012, 08:14:51 AM »
looking again what about handle bars hitting the tank??
going to fit risers to bring them above Smiley
Pah! Which then clobbered the tank. So the tank has been moved back a bit now. The 7/8 CDS tube seems plenty strong enough, going to bend up the bars today and fit them, then I gan have a good rive at them and see if they flex.
Also started laying out the dash on the PC last night. We are stripping out the gubbins of various clocks and remounting them all behind a single sheet of clear plastic. A printed front will stick to that with the LEDS for illumination behind, shining through the white parts of the printing.  We are following some of the ideas in this link:
http://www.instructables.com/id/DIY-LED-Tachomter-RPM-gauge/
« Reply #215 on: September 23, 2012, 09:07:28 AM »
Fair play, that looks to complacated for me I'll stick with something i know already works  Grin
andyrennison
« Reply #216 on: September 23, 2012, 11:40:50 AM »
Did a lot of electronics in the past Merv (3 years running international amateur TV champion!) So that holds no fear for me Smiley
« Reply #217 on: September 23, 2012, 12:08:59 PM »
Andy are you a radio amateur by any chance?
« Reply #218 on: September 23, 2012, 12:11:15 PM »
Looking good there Andy. on the seat spring it look as if. they need to come up a bit the angle looks to steep. for them to work properly. as for the steering stops don't it have to be a welded pin on the headstock that the bottom yoke to stop against
andyrennison
« Reply #219 on: September 23, 2012, 06:55:25 PM »
Yep. Old timer now - G8LIR - got my licence in 1972 only 14 at the time!  Did loads of ATV back in the day. All home brew gear including the receivers. And a pair of 4CX250's with 2KV on the anodes in the transmitter to a set of 4 x 40? element yagis fed with Andrews LDF450 coax. Happy days.
Are You ?
andyrennison
« Reply #220 on: September 23, 2012, 07:00:53 PM »
Hi Terry - Cheers. I Fiddled about with the springs a bit, more steep and they didnt compress, I bought 750 Lb/sq inch, probably too much with having 2. I;ll see how it behaves on the road then fiddle Smiley
Yes, the steering stops. I did wonder about welding something to the headstock as the "bumps" are still on the bottom yoke. Ive no idea which approach is best though.
« Reply #221 on: September 23, 2012, 07:42:58 PM »
Yes Andy my call is GI0ZER licensed sinse 1996, it's a hobby that come's in usefull in many ways...are you still active
andyrennison
« Reply #222 on: September 23, 2012, 07:57:44 PM »
Hi. Sadly not. Still got an FT221 sitting in the workshop. One day maybe ......
andyrennison
« Reply #223 on: September 23, 2012, 08:06:03 PM »
Spent hours with Will today bending a nice set of swoopy barsgot them up the the risers and was not happy at all with them. Then we relooked at the bars we decided not to use, and they look fine on the risers. Ah well, live and learn hey!
« Reply #224 on: September 23, 2012, 08:22:56 PM »
I've made & re-made parts for my truck 2 or 3 times. Despite all our plans & measurements & sketches, or even computer designs, sometimes you just need to make bits & try them to see if they're gonna work or not.
